Question about Kicker Car Audio & Video
I have a taramp 5k and keep burning subs so I am getting new subs from kicker and have a choice of 2k or 3k amps but don’t know which too choose 2k will under power but I feel 3k is just right just do t want to burn no more subs need advice 2 15” l7s subs
Posted by Vish Persaud on
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: Help with CVR 12 (kickers) and a Power 1050 s amp (Rockford Fosgate)
Send me your email account and i will draw you a diagram and send it to you there. I will need to know if the ohms of each sub as well as the amp. I'll also need to know if the subs come with one or two voice coils.
Ciza
Posted on Nov 04, 2008
Anonymous
SOURCE: kicker l7
hook them up parellel for 1ohm load
Posted on Nov 24, 2008
Anonymous
  • 22 Answers
SOURCE: voice coil makes burning smell
a lot of subs will make a smell when hot. if there is no indication of blown subs turn your gain down on the amp a quarter turn see if that helps. same with bass boost.
Posted on Jan 09, 2009
Anonymous
  • 14 Answers
SOURCE: the fuse from the amp to the battery keeps burning
maybe it cannot accomodate too much power running on it...too much current, try another fuse with higher ampere rates
Posted on Jan 14, 2009
gdcroft
  • 192 Answers
SOURCE: what does sub sonic mean on my Kicker kx1200.1 amp? Do it need to be off or on?
Subsonic refers to frequencies too low for the human ear to hear. Generally humans can hear frequencies in the range of 20 to 20000 hertz (cycles per second), but we hear best in the range of 1000 to 4000 hertz. High amplitude subsonic frequencies can cause damage to your speakers so many amplifiers have an electronic filter in them to reduce the amplitude of these very low frequency signals.
Posted on May 21, 2009
So I just bought a kicker cx 300.1 mono block amp to run my 10 inch comp d 4 ohm 300 watt sub. I ran it parallel and it smells like the coils are burning. Help
That's only normal for the burn in period. Make sure you're not running it in 2 ohm by wiring the sub wrong. That amp is not really 2 ohm stable for a sustained period
Feb 03, 2015 | Kicker Car Audio & Video
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
What Amp would i need to push three Kicker L7 12's?
It depends on the specific subs and exactly what you want out of them. You have practically unlimited choices for amps.
The 10" L7 has a power range of from 30-600 watts RMS, the 12" from 50-750 watts, and the 15" from 100-1000 watts.
So if you have the 10's, you would want an amp that puts out at least 90 watts RMS and not more that 1,800. Unless you are really into SPL and have an unlimited budget, it's probably best to go somewhere in between.
Keep in mind that these Kickers need to be in a proper enclosure. They like a little more volume to work as compared to RF's or MTX's and some others.
Mar 30, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
AMP shuts off
your problem could be in the fact that you are trying to overdrive the amp. sony will not carry a 1 ohm stable load and if your speaker are 4 ohm speakers wired in series then you cant drive the bass your looking for. try using soundstream tarantula amp or new hifonics block mono class d amp with about 1000 watts rms. what kicker subs do you have? that will also make the difference in amp choice. im running tarantula on 4 polk momo 4 ohm 12's and has broke my back glass in my jeep twice one time was for a show. oh well let me know. happy boom boom. i'll be glad to help
Feb 28, 2009 | Sony Car Audio & Video
How to order
The L7 I have is brand new in the box (not a speaker box just the retail packaging box) and the rms is 750 watts RMS and 1500 watts peak, but you are correct they blow easy when you push rated power to them, the hifonics subs will take 1200 watts rms all day long and over 3500 peak for burping at competitions, i run mine at 2000 watts everyday in a daily driver. if you hook 1 dual 4 ohm sub to a zx1000.1 it will be 2 ohm load on the amp so you will get 1000 watts to the sub so if you want to run it slightly underpowered to keep it from blowing use the 750.1 per sub, i can do those at about 250 each shipped
the price is 150 plus 10$ flat rate USPS shipping and yes I accept paypal [email protected] .
the warranty starts the day you buy it for 12 months but kicker will not cover burned or blown voice coils, that is why i recommended the hifonics (which is what i use to compete with now) because they put out better quality sound and alot more of it and they will take alot of abuse, if you want boxed speakers ready to go in kicker brand ported boxes I can have them drop shipped right to your door as well, the only reason i am selling the 1 L7 i have so cheap is because a customer ordered it then never paid for it so I am selling it at cost. be careful if you are buying on ebay as you have no warranty at all and you cant force the seller to give you 1 even if they say it has 1. because authorized dealers are not allowed to do internet sales at all so kicker and most other companies will not honor the warranties.
also you dont need 2 amps you can use 1 bigger amp and still run 2 subs just by changing how you wire the subs at the amp. 1 large amp costs less than 2 smaller 1's usually just not with kicker brand
Sep 15, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker 06ZX750.1 Car Audio Amp... Problem
Kicker amps are good amps, I would weigh the cost of a new one against getting this one repaired and go from there.
Dec 06, 2007 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker zx850.2 and two kicker s10l72
http://kicker.com/dvc_wiring , check this out. for that set up i would recommend either getting a mono amplifier or dual 4 ohm subs. hope that helps.
Sep 24, 2007 | Kicker ZX850.2 2-Channel Amp - 590W ZX...
What amp to use
recommended maximum for the sub boxes is 1600/800 here is the link to the manual if you need it; http://www.kicker.com/06/tech-support/manuals/manuals/2007/2007%20CompVR%20Box%20d01%20Web.pdf If you really wanted to get the maximum from your subs then a zx750, or possibly a zx1000 would be the ideal choice. Either amp you suggested will work, but you will have more fun with a 750 which should do fine. Hope this helps :)
Mar 17, 2007 | Kicker ZX400.1 Car Audio Amplifier
Car Audio & Video Logo
146 people viewed this question
Top Kicker Car Audio & Video Experts
Marvin
Marvin
Mike
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
