SOURCE: Epson Stylus CX3200
SOURCE: i want to add my cx3200 epson printer to my pc have lost the cd rom disc
Download these two drivers in order and install, follow prompts to know when to connect printer.
Printer Driver
ftp://ftp.epson.com/drivers/epson10453.exe
Twain Driver
ftp://ftp.epson.com/drivers/epson10573.exe
Hope this helps
Thanks!
SOURCE: Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will
help us determine what cause the red light. To give you heads up as well, the
Printer's LCD screen can help us determine what exactly the offline condition
of the CX3200 is:
Error
message: No color or black ink cartridge-->Press the Color Copy button to
install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the
necessary cartridge(s).
Error
message: Color or black ink out -- >Press the Color Copy button to begin
replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace
the necessary ink cartridge(s).
Error
Message: Ink cartridge error -- > Press the Color Copy button to begin
Solution: There is something wrong with the ink cartridge. Make sure the
cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and
then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and
clear the paper jam by hand if necessary.
Solution:
Paper is jammed. Check for any obstructions under the unit's cover, and in the
paper tray.
Error Message: Paper out -- > Load paper in the sheet
feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button
to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks
securely into place.
Error Message: Scanner error -- > See your documentation and call service if
necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the
transportation lock, if necessary. If it is already unlocked, toggle the lock
back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message:
Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect
it from power, and then reconnect it to power. Press the ON button to turn on
the Stylus CX3200.
SOURCE: Epson cx3200
EPSON Stylus CX-3100 Printer Driver for Windows 2000/XP
Download File Name : CX3100_win2000_XP.zip (4.4 MB)
Note - epson Stylus cx 3100 is similar to cx 3200.
SOURCE: my epson stylus cx3200 is not printing in black
If you are brave I had the same problem. I removed my ink disconnected the data ribbon to the Head. Took off the nozzles. I used a child's med. syringe with the tube. Filled it will rubbing alcohol. placed the tube on the head where the ink cartage attaches and slowly put pressure on the syringe. Be care full it will flush the black ink everywhere. I kept doing this till the black was all flushed out. Put it back together. make sure you put the ribbons back in the right way. Mine works great.
