you either have a paper jam or the scanner module has jammed. open the printer and check the paper path for possible jams. then open the scanner lid and make sure the scanner light bar is in the home position at the end of the scanner deck and not stuck mid path.
Green light flashing means printer is in printing process. No problem. If you want to stop printing. delete printing job from printer properties or stop printing from status monitor.
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing? If you get no noises this usually indicates a board fault and you should look for a new printer.
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
