The display on the screen has shifted about 1/4 inch to the left. obscuring the scroll down bar, maximize button and x button. How can I center the display again. I have Microsoft XP 2002 Service Pack 3. I did change my resolution to 1024x768 last night which helped a lot but the black bar on the left remains for all users from the user account screen throughout all use
if your lucky it's just your H-center is off tilt. to check this Press the menu button on your monitor. scroll through the options till you see Horizontal-center option. select this setting and move the screen to the left. The entire screen should start shifting to the left and fill in the screen. now if you do this and you get a black bar on the right. Center the screen where you have the same amount of black on both sides of the screen. scroll through your menu till you see the H-size. increasing this will fill in the black area. Hope this helps.
hi... It sounds like an Intergrated Circuit (IC) has fried. Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
Hi you may try
1)to key the auto(adjust) button at TV monitor keyboard if not ok,
2)to change display pixels density from PC display setting because TV monitor could not support the display pixels you using and sync.the picture on well.
3)also you may adjust monitor screen H position(it maybe not convenience for back TV).
Try the Auto adjust button on the monitor buttons first.
If the entire picture of the computer is showing you can try to shift and stretch the picture through the menu button.
You can adjust your display through 1 of two ways.
1. Somewhere on your monitor are buttons that allow you to adjust your screen position, ( left- right-up-down, widen / stretch in both direction, up & down at the same time & left & right at the same time. If you still have the manual for the monitor it will explain how to do this. Every monitor is not the same & each monitor has their own way to adjust monitor positions.
2. This might be a bit harder but all you'll need is youe mouse.
Find an emty space on your desktop, ( yeah I know it's messed up right now, did I mention this would be harder?).
I want you to right click once on your desktop & that will open a small pop-up menue. Left click once on Properties
You have just opened your display Properties. ( I need to mention just like the monitor adjustment screen is different from one to another, your video card will also be different.) My instructions should be close for you to adjust your screen.
So you have Display Properties on your screen. Click the settings tab, than click the Advanced button. Here click the Adapter tab. Look down & you'll see a button ( List All Modes).
Click it. The mode screen will open. There is a scroll bar on the right. Slide the scroll bar down & pick out the setting you want.
Most people use setting - 1024 by 768, True Color (32bit), 60 Hertz
Click Ok & than Apply. Your screen should adjust it's self.
If it does not, than someone messed with the monitor adjustments & you'll have to re-adjust from the monitor.
it depends on what type of PC you have but basically you can go to "my computer" and "display" - change the "resolution" to the next higher setting - this will shrink the screen to fit your window [dxh]
