20 Most Recent X2Gen MG19MY 19" LCD Monitor Questions & Answers
check connections pull plug and replug
X2Gen MG19MY 19"... • Answered on Jul 06, 2015
Internal Switch Mode Power Supply or it's fuse. It needs a technician.
X2Gen MG19MY 19"... • Answered on Sep 08, 2014
Have you tried another monitor, the issue pretty much sounds like is from video signal. pc video card adapter!
X2Gen MG19MY 19"... • Answered on Mar 25, 2014
post a picture or list the caps you need.
Robert, Did you try opening the lcd ? all those switches connect to the power supply. I would go ahead and check and trace the switches with cabling to the power supply. I just replace some transistors on 2 of these (22") and they work like a charm. Al
Need more information to assess your problem.
X2Gen MG19MY 19"... • Answered on Apr 04, 2012
There a inverter board that needs to be..
X2Gen MG19MY 19"... • Answered on Sep 17, 2011
HPA-501242U3 C0-A11 ,found one cheap 22 dollars total on ebay ,good company,utopiadreamglobals.gif
X2Gen MG19MY 19"... • Answered on Jul 22, 2011
The monitor needs an internal eletronic repair. Do you have the the necessary anti static tools including soldering iron. If so I can help you with the repair, else take it to a pro.
X2Gen MG19MY 19"... • Answered on Jul 14, 2011
I had the same problem with my 22" X2Gen, first the monitor started what looked like a random color temperature shift, ie the screen would switch between a yellowish and blueish tint, then it wouldn't turn on and the amber standy by light flashed on and off. I took it apart and replaced the 2 220uF25V capicators with 2 220uF35V caps I got at radio shack, part number 272-1029. Don't worry about the voltage mismatch I'm pretty sure it doesn't matter, the voltage is the maximum the cap can withstand and has nothing to do with the voltage in the circuit. The caps are located on the board that the AC cord plugs directly into, it has a plastic (almost feels like paper) sheild, the caps are marked C812 and C813 on the circuit board. There was no 47uF35V cap that I could find, anyway replacing the two did the trick, all for under $3, I almost went out and bought a new monitor ;) Hope that helps.
X2Gen MG19MY 19"... • Answered on Jul 10, 2011
Had the same problem with mine. First you need a volt meter (radio shack about $15). check the push in connector and make sure it has coming from it.
Place you meter on DCV for DC voltage, Then place one lead in the end of the plug in the hole. (will not fit all the way so will need to hold it there, Put the other lead on the shiny part of the plug. If you get a reading of 12 volts +/- 1 volt your good. Depending on which lead is were you may get a minus reading this is fine as if you switch your leads around it will go positive. you must have the cord plugged into the wall to do this test. You will not get shocked or anything as 12v is not enough to hurt you.
If you have the 12 volts the problem is in the monitor on the male plug or on the board. this takes more to fix and must take the back off the monitor and fix the connection or replace. I did this to mine and it is working right now.
X2Gen MG19MY 19"... • Answered on May 25, 2011
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details or if you have any questions.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
X2Gen MG19MY 19"... • Answered on Apr 17, 2011
Double-check to see if the cable is properly attached and the monitor is set up for DVI(digital) or RGB(analog) depending on which cable it is. Or you can set it to Auto, that normally works.
If you still cannot get a picture try a different monitor or verify the computer is starting up. Sometimes if you fondle with the memory or other internal components the video will not show, thus the computer is not starting at all.
X2Gen MG19MY 19"... • Answered on Feb 28, 2011
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC
X2Gen MG19MY 19"... • Answered on Feb 22, 2011
I had this happen to me, it finally wouldn't come on and I found 2 ballooned capacitors on the power board, they were 220uf 25v electrolytics, I replaced them and the problem went away immediately.
X2Gen MG19MY 19"... • Answered on Feb 21, 2011
No signal is not a problem with the monitoe unless the cabe is disconnected from either the PC or the monitor ends.
If the cables is securely attached at both ends it indicates the PC is not sending a video signal to the monitor.
Could be the PC hasn't booted up propperly.
Turn the PC off , wait 2 minutes and turn it back on.
Observe any lights on the front of the PC , especially disk activity light.. it should flicker .. alot.
If not then you have a PC issue not a monitor issue
X2Gen MG19MY 19"... • Answered on Jan 21, 2011
It is saying out of range because the PC video resolution is too high for the monitor to display, it should be set to the native resolution of the monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/ Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
X2Gen MG19MY 19"... • Answered on Jan 13, 2011
4 years monitor will more likley to have bad caps by now, which is very common problem as you can see in my albums, that will be the first thing to look for.
X2Gen MG19MY 19"... • Answered on Jan 12, 2011
X2Gen MG19MY 19" LCD Monitor Logo
190 questions posted
Top X2Gen Computers & Internet Experts
Michael Thomas
Michael Thomas
scramblepad
scramblepad
Richard C Cohen
Richard C Cohen
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • X2Gen Computers & Internet
Most Popular Question
x2gen 22 inch monitor black all time
  • Computers & Internet
