Expert
- Posted on Jan 29, 2010
Re: I cant scan to computer
- Position the document on your scanner.
- On the File menu, click Scan New Document.
- In the Scan New Document dialog box, select the options you want.
- To select additional scanning options, click Preset options, and then click either Create new preset or Edit selected preset.
- If you want to scan a double-sided page, select the Original is double sided check box.
- Click Scan.If you selected the Original is double sided check box, the Scan New Documentdialog box reappears as necessary.
- If you selected the Original is double sided check box or the Prompt for additional pagescheck box, click Done to save the file after the last page is scanned.
Note By default, OCR is performed automatically when you scan documents. To turn off this feature, click Scan New Document on the File menu, and then click eitherCreate new preset or Edit selected preset. On the Processing tab of the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned imagecheck box.
Hope this helps!!!
Please rate my response!!
