Doesn't heat completely during foaming and light blinks
This is either a problem with the thermostat that lives just under the surface of the bottom of the aeroccino jug and is a technical problem that can only be resolved (replaced) by returning it to Nespresso OR it is related to a fine layer of burnt milk that builds over successive use that builds and holds the heat the element produces 'tricking' the thermostat into thinking the milk itself has heated to the desired temperature, not just the burnt layer. Clean the bottom of the jug, regularly with a non scratch scourer and use a mild detergent as well.
Hi
If light is blinking then it may be an
issue with heater circuit, door switch or the thermal fuse, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry.
Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button
and allow it to completely drain and reset. If this doesn't work then it's an
issue with the thermal fuse located on the control or the door switch that is bad and should be replaced. Hope this helps... Please post
back if you need more information.
Daniel
Hi
If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
energy saver dry. Now let the unit run for 2-3 minutes and then you press
the Cancel/Drain button and allow it to completely drain and reset. If this
doesn't work then it's an issue with the wash pump not pumping the water past
the heater efficiently or due to lack of water to heat. Please make sure that
heater is not open circuited and is heating the water efficiently. You'll have
to check the heater using a multimeter; the meter should read between 3000 to
3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure
water pressure is optimum and fill valve is working fine. Hope this helps...
Please post back if you need more information.
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
