Question about Nespresso Aeroccino Automatic Milk Frother
What does a it mean if the aerocino is flashing its red light?
Normally when i look it has switched off but today it was flashing.
Thanks
Diane
Posted by dgott179 on
  • Vincenzo Morreale
    Vincenzo Morreale Jun 09, 2015
    When you are finished frothing, turn off by the main, and you would not have that problem. Most important you will avoid all the problems below.
Anonymous
We had the same thing, and I think it has to do with overheating as well.
After about two goes of frothing hot milk, a little bit of burnt milk residue had formed on the bottom of the jug. I think that "fools" the temperature sensor, and makes it "think" the milk is hot before the frothing time is up (then shuts the machine off, blinking the red light).
As soon as I cleaned the bottom of the jug (had to scrape it with my nails after leaving water in for a while), all systems were "go" again......
My remedy: rinse the jug quickly with cold water after each use, making sure the bottom stays clean!
Posted on Oct 18, 2009
Anonymous
  • 3 Answers
Its basically due to it overheating. 1, Make sure the bottom is not scratched. 2. Make sure the frother is not coming off. 3. Wash it between spins so it can cool down. 4. clean any muck off the bottom.
I rang them up and the above is what I was told. Also put the metal whisk in and fill it with water and let it go as well to prime it. Cheers, Paul
Posted on Oct 16, 2009
  • George Jost
    George Jost Jul 03, 2016
    Hi, the freezer solution sort of works. Better solution: heat milk in microwave 1 minute and use cold setting to froth. Pretty obvious the heat generation and detection is poorly designed but there are lots of ways to heat milk.
marie kirkwood
    New Friend:
My aeroccino was doing the "red light blinking" too so I checked the manual (no troubleshooting tips there) but I came across these tips here (thanks for posting!).
It didn't seem to be working for me at first but I did end up getting it going again. Here is what I did.
1. I removed milk from jug and cleaned thoroughly. Tried it again but it still didn't work (red light goes on froths for a bit then red light starts blinking continuously).
2. I put some cold water in the jug. Worked fine but when I switched back to milk it wouldn't work.
3. I switched the attachments and tried water again. Worked fine but when I switched back to milk it wouldn't work.
4. In the end I had to hold the jug firmly on the base and then press the button. That seemed to do the trick.
I ran another water cycle through it with both attachments just to clean it out and both times it worked fine.
I hope it works ok the next time or I will be trying these steps again but in reverse order!
BTW mine had been sitting overnight and this was the first attempt in the morning when the light started blinking. I'm not sure how it could have overheated since I hadn't used it at all yet.
Posted on Jul 10, 2015
  • Lenny T Jul 14, 2015
    Same thing with mine, if I hold it down firmly and the base it works soon as I take my hand away it stops, thanks for letting me know I'm not crazy
Anonymous
  • 5 Answers
It should not be flashing - sounds like some sort of electrical short. It has two settings - on and off. If it's flashing... it's not either of those settings! I would call for service.
Posted on Aug 30, 2009
  • Heather Eyre
    Heather Eyre Dec 08, 2014
    It is a warning flash (overheat) that occurs partway through heating. Not a short.
Y Vay
    New Friend:
Not only you have to clean the bottom of the machine, you also make sure the whisk spring is even all around. On mine, one side was lower than another, so when I straightened the spring, everything works fine.
Posted on Feb 18, 2012
Peter Reynolds
    New Friend:
I also had the flashing red light when attempting to make hot milk froth. My cold operation (blue) was also working fine. My uint was also super clean and had no buildup.
Here is my fix:
You need to take the unit to a nice work surface where you need to flip it upside down. You will notice 3 slots in the back. Very cautiously use a flat head screwdriver apply leverage against the plastic slots and resting your screwdriver against the metal edge, slowly work around the bottom of the unit and pry the plastic unit out of the metal housing. It is held in place with an o-ring seal and 3 plastic tabs. It will eventually come out, so be persistent.
Once the last housing and motor assembly are out you will notice 3 spring tabs. These tabs make contact with the heading element inside the metal brother housing. Carefully bend slightly outward on all three metal spring contacts. Re-assemble taking note of the rubber switch cover. The rubber switch cover needs to come out of the brother body and be installed over the switch before reinstalling.
Bending the metal springs slightly makes a greater contact with the heating element inside.
I did this and my unit now works perfectly again.
Posted on Aug 22, 2015
  • Jacqueline Hunter
    Jacqueline Hunter Feb 03, 2019
    can confirm - this solution worked great. a couple tabs broke off but unit seems to be holding together well enough for me!
  • Jacqueline Hunter
    also, thanks, Paul!
James Nel
    New Friend:
Had the same problem and it was a super easy fix! Just cut off the thin part on both sides of the little spinning paddle! The spinning of the tiny black "paddle" creates a vortex that causes the machine to overheat at a single point.
what does a it mean if the aerocino is flashing it - 10_31_2016_2_47_17_pm.jpg
Posted on Oct 31, 2016
Austin Davis
    New Friend:
Mine was blinking after the milk was "frothed" but it had stopped early due to overheating. Solved by making sure there was no milk film left on the bottom of the jug before use as this tricks the thermometer into thinking its overheated.
Posted on Feb 01, 2015
Craig
    New Friend:
The problem is that the thermocouple has not reset. Simple fix.
Place dry - dry unit in freezer for 15 -20 minutes. Remove and ready for action. Be careful that next batch of milk may overflow when heating due to cold temp of container!!
Cheers
Posted on Jan 31, 2015
Ole Valle
    New Friend:
    Problem Solver:
I got this problem once, and I didn't understand what was going on. Thinking maybe some water got to the electrical parts etc. The answer was that I didn't place the whisk correctly on it's place. When I checked, it was actually not sitting on the tap, but just on the bottom of the container, close to the tap.
Posted on Dec 27, 2014
My Cuisinart soup maker keeps switching off
How you removed the bottom? Screws are so deeb and I cant see what screwdriver I have to get.
Nov 20, 2012 | Cuisinart SSB1U Soup Maker
I have a Bosch Maxx 1000 Washing machine and it seems to be stopping just before spin dry and flashing end. Door won't open so I need to turn to spin or drain to complete cycle. Today the spin cycle...
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Jan 22, 2011 | Bosch Washing Machines
2002 VW Golf TDI - Live in northern ontario - -20's with wind chill. When I first drove the car this morning - error code (looks like a clock) on upper right portion of speedometer gauge. Just flashes on ...
Classic 109 relay failure.
Relay is for the Glow Plug system.
This relay provides the power to all of a TDI's engine-based electronics.
If the glow plug light comes on intermittently by itself, check your brake lights too.
A burned-out bulb will cause the glow plug indicator light to come on. Sometimes flashing is caused by a bad Brake Lamp Switch on the Brake Pedal. It was updated for free by VW .
If you can see it under the knee panel, the Brake Lamp Switch body should be Metallic Green....if it is Purple or Black it need updated.
Jan 14, 2011 | 2002 Volkswagen Jetta TDI
I need to remove the console on my treadmill in order to move it to another room - can you give me a run down on how to disassemble that part? thanks, Diane
Hi Diane
Look underneath with a flash light the electronic console has on each side 2 allen bolts holding the console to the up rights.A cable is also going into the upper display first must be disconnected by gently prying off that console cable cover. Remove the bolts I believe with a 6 mm allen wrench and that should do it. reverse that order when reassembling.
Apr 12, 2010 | Horizon Fitness 725T Merit Fitness...
Lock disc mechanism stuck
Try to put some silicone oil to the thread the disc is turning on. The oil slowly penetrates into the gap and lets the disk rotating. Car dashboard shine sprays often contain silicone oil, check the ingredients.
Laszlo
Nov 13, 2008 | Promaster 7500DX for Canon TTL Flash
Webcam video email
you can save your video to wma , 3gp or any other playable formats, so that they can view it in a third party softwares like realplayer , divx or winamp etc..
or maybe they should install the latest activex and adobe flash player.
i hope it help.....
Aug 06, 2008 | Computers & Internet
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
My laxmark x9350 and vista
I talked to DEll and they walked me thrugh it . Thanks, Diane
Feb 26, 2008 | Lexmark X9350 All-In-One InkJet Printer
Nespresso Aeroccino Automatic Milk Frother Logo
42,516 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Ekse
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
