You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem. If a problem occurs while you're printing, you'll see an error message in the progress window on your computer. It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable CauseNo color or black ink cartridge - - > Press the Color Copy button to install a new ink cartridge.The indicated cartridge is not installed or it is installed incorrectly.Color or black ink out - - > Press the Color Copy button to begin replacing the ink cartridge.The indicated cartridge is out of inkInk cartridge error - - > Press the Color Copy button to begin replacing the ink cartridge.There is something wrong with the ink cartridge.Paper jam or misfeed - - > Press the Color Copy button and clear the paper jam by hand if necessary.Paper is jammed. Press the Color Copy button to clear the jam. See the User's Guide for more troubleshooting tips.Paper out - - > Load paper in the sheet feeder and press the Color Copy button.Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing.Scanner unit open - - > Close the scanner unit.Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place.Scanner error - - > See your documentation and call Service if necessary.Press
the On button to turn off the EPSON CX3200. Check the transportation
lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If
the error message still appears, contact your dealer or EPSON.Printer error - - > See your documentation and call Service if necessary.Press
the On button to turn off the EPSON CX3200, then press it again to turn
it back on. If the message still appears, contact your dealer or EPSON.
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
I have a canon pixma 780. It was working fine then I had a paper jam and message "Cartridge jammed" I removed paper with no difficulty-piece was not torn.Now it will not print at all Paper feeds through but no printing in any colour
the E error message is for 2 reasons.either its a paper jam in the printer or the cartridges r faulty.there r two cartridge 1colour and 1 black.as 1 of them may had gone faulty.just replace the cartridge and it will work properly.
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad
or the printer cartridge Slot is bad... I would suggest you to try
cleaning the copper contacts of the both carts and cart slot in the
printer and try again..
If that doesn't work just call up their support number and check for replacement..
