Can I set up a pair of bluetooth headphones to my Kenwood KR V5560 Stereo Receiver?
I had an idea that it would be nice to have over the ear bluetooth headphones to listen to records from my receiver at home. I'm not sure if this is possible or what kind of headphones would work. Any help?
Are you trying to play music off your computer through a stereo or receiver??? If so you will need a cord with red & white (rcas's) on one end & an 1/8" jack on the other...Run it out your headphone jack of the pc (usually color coded light green) and turn input of stereo to corresponding input you plug into..
Should not be a problem. If you download the quick start guide from this site and follow the pairing instructions for your Bluetooth phone that should work well. http://www.jbl.com/images/media/J46BT_QSG_EN.pdf
you need to make sure both the Kenwood and the LG have bluetooth enabled. Then you pair the two using the pairing function in the LG. Hopefully this should enable you to play music from LG on Kenwood and also receive calls. As you have not provided any model numbers it is difficult to say whether the phone and your Kenwood audio systems are compatible.
Best to go to this website and select the correct model numbers and find out which features in your LG phone will work with your kenwood.
If they are Bluetooth headphones make sure they have fresh, fully charged batteries, go to System Preferences and open the "Bluetooth" panel, click on the "+" sign near the bottom left of the page and follow directions to pair headphones to your computer.
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset * Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped. And please don't forget to rate me...
Press power (small triangle) and vol up (small thin button on the side near the led light) buttons together for 4 seconds until it goes red/blue for pairing (up to a min). Passcode is 0000.
