Hi all, I have a Canon PIXMA MP160 printer that used to work fine before. I recently moved, and when plugging the printer in again the green "on" light shortly turns on, then off again after which the orange alarm lights stays on. At this point the printer doesnt respond to pushing any buttons (even the on/off button). My PC recognizes the printer and I can click print on any document, but the printing progress bar closes itself after a few seconds and nothing happens. Any idea what is going on? Thanks in advance!
Try doing a Reset.
Reset Printer Canon PIXMA MX310 or Canon MP160
More items...
Feb. 28, 2017
Reset Printer Canon PIXMA MX310 or Canon MP160 - Printer ...
Testimonial: "Hello, many thanks for your answer. Unfortunately this didnt work. Orange error light now flashes, but still the other buttons don't respond nor is the printer going in service mode. Any idea what else could be the problem?"
Okay. One your computer, go to Settings - Apps and uninstall all of the Canon Software and drivers. Check in Settings - Printers and make sure it is gone. Reboot the computer and then reinstall all the Canon Software and Drivers. Then in Settings - Printers see if you can print a Test Page?
If that doesn't work, you will need to take it to a Canon Service Centre for diagnostics and probably a new print head.
SOURCE: canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not
print. I re installed the drivers but no result. When try to print
message appears printer is offline. POwer button is flashing shorthly
green after orange lights. Error code 5100.
Please advice what can I do urgently.
SOURCE: Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
SOURCE: Hi My Canon Pixma iP5300 injet printer will not...
the problems are :-
