Where can I get a replacement?
SOURCE: How do I use the
Hi check this video link ,on How to use the pizza stone.
thanks for the rating
Good luck
SOURCE: I purchased a Breville Electric
Try to soak it first with some solution used for cleaning the gas range ...and let it stay with the detergent on for a while (about an hour ) and after that try to clean it and see what is going on ...repeat the procedure if needed..and also rinse it well cause it will be in contact direct with the food..
SOURCE: Pizza dough sticks like glue
There are about three things you might consider.
First, you can sprinkle corn meal lightly on the stone and this will help prevent your pizza dough from sticking.
If you're already doing this, you might try spraying with a pan coating before you sprinkle the corn meal on the stone.
Additionally, most of these stones require "seasoning" which is done by rubbing the stone lightly with vegetable oil and placing into the oven at about 300 degrees. Let it heat until the oil starts to smoke. Turn off the oven and let the stone remain in there until it cools. DO NOT WASH IN SOAP AND WATER.Just use a damp cloth to clean.
I hope one of these suggestions help. If they do, please come back to Fixya and rate my advice.
The Web
Restaurant Store sells pizza cutter blades for a good price, although as the
pizza cutters themselves are not expensive, you might find it just easier to
buy a new one.
