Question about Vacuums
No instructions with Paderno pizza stone!!!! - Vacuums
Posted by sandbeach on
Anonymous
    Scholar:
  • 159 Answers
Nothing to it. Just pre-heat the stone for 15-20 minutes at 425-450 degrees. Slide your prepared pizza onto the stone and cook. ps best to prepare your pizza on a pizza peel or cookie sheet so you can slide it on to the stone. Cook around 10 minutes or so. Good luck and enjoy your pizza.
Posted on Mar 08, 2011
The motor grinds and sparks when on. Bearings or brushes or both? thanks
  1. Pull the brushes.
  2. Check how the motor turns. You can tell if bearings need to be replaced.
  3. Pull the motor and take out the rotor. Dress the commutator and get it clean. If you are lucky you can dress the commutator well enough with a hand held carborundum stone.
  4. Bearing are cheap. Consider replacing the bearings just because it is easy to do now.
  5. Reassemble and replace the motor.
  6. Replace the brushes.
Mar 15, 2015 | Vacuums
Loud noise when running
It may be a broken fan. You will have to disassemble it to find out.
Jan 16, 2014 | Halo UVST Bagged Upright Vacuum
Rattling noise coming from upper compartment
remove the suction port covers at both of these locations:
Dec 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do i clean stonework from grout stain
I have been at a loss where to find a good grout stain. I used a lot of mine left over from my construction days and it turned out not like I want it and my wife wants a different color.
Nov 24, 2012 | Vacuums
My h2o steam mop does not produce steam.I have only used it 6 times. I have tried using 1 part vinegar and 2 parts water to clean the system but no joy.
The H2O Mop X5 is designed to thoroughly clean floor surfaces, such as marble, ceramic, carpet, stone, linoleum, and sealed hardwood floors and parquet. Not all floor types are suitable for steam cleaning. For more details about h2o mop please visit ADS TUTORIAL
Oct 28, 2012 | Vacuums
Need replacement part for PIZZA baker mod: PS75891, it is a thermo switch No.E211649. this is counter top pizza oven
I don't see any parts available for this, most parts are propriotory and can't be purchased seperatly. I checked online and this is selling for around $60.00 new and it seems that this oven has been discontinued. If you know what part it is you might be able to match it up at a local electrical supply or appliance repair. I have no idea what a new switch would cost but at $60.00 replacement of the oven might be a better choice.
Dec 23, 2010 | Vacuums
My dyson D17 is making an incredibly loud noise, like grinding, when the bottom brush rotates.
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
Aug 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Lack of information before purchase
Hi. I think I can put your mind at rest.  I work in a Flymo service agency. The Flymo Contour Cordless Power Plus has a guide wheel for accurate edging but, in common with all other Flymo edgers and trimmers, the actual cutting is done by a whirling thin (1.5mm) plastic cord that is designed to wear out and is fed from a replaceable reel under the cutter shield.  The only risk in cutting up to stone, concrete or other hard material is rapid wear of the plastic cord.  Unless your step is made of exceptionally soft stone there is no reason to think that the step will be damaged at all.
Good luck.  If this helps, please rate my response.
Apr 14, 2009 | Vacuums
Vacuums Logo
922 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
