20 Most Recent
Rosle Digital Multi-Timer 19222 Questions & Answers
What do bedbugs look like ?
use this link to see:
http://www.medicinenet.com/image-collection/bedbug_bites_picture/picture.htm
1/23/2023 6:05:21 AM •
Home
Answered
on Jan 23, 2023
My invacare bed head section won't go up to 90degrees and I need it too. Is that a possibility???
It is possible that the head section of your Invacare bed is not able to raise to a 90-degree angle due to a mechanical issue with the bed. It could be due to a problem with the motor or gears that control the movement of the head section, or it could be due to an issue with the electrical components that power the bed.
You should check the following things:
- Check the bed's remote control to ensure that it is functioning properly.
- Make sure that the bed's power cord is securely plugged into the outlet and that the outlet is working properly.
- Check the bed's battery level, if the bed has a battery backup.
- Make sure that the bed is not locked in place or that the manual lock is not engaged.
- Check that all the bed's connections are secure, and all the bed's cables are properly plugged in.
If none of these solutions resolve the issue, it may be necessary to contact the manufacturer or a healthcare equipment repair service for further assistance.
1/23/2023 5:58:29 AM •
Home
Answered
on Jan 23, 2023
I have an existing ceiling fan/light unit using the Intertek 3177973 unit. I want to install a second unit for the same light. How do I pair / sync the second remote switch to the existing receiver??
To pair/sync a second remote switch to an existing Intertek 3177973 receiver, you will need to follow these steps:
- Turn off the power to the existing fan/light unit by switching off the circuit breaker or removing the fuse.
- Locate the "learn" button on the receiver. It is usually located on the back of the receiver or the control box.
- Press and hold the "learn" button on the receiver until the LED light on the receiver starts flashing.
- Press the "on" button on the new remote switch for about 5 seconds. The LED light on the new remote switch should start flashing.
- Release the "on" button on the new remote switch. The LED light on the new remote switch should stop flashing, and the LED light on the receiver should stop flashing.
- Test the new remote switch to make sure it is controlling the fan/light unit properly.
7. Turn on the power to the existing fan/light unit.
It's important to note that these steps are general guidelines, and the specific steps may vary depending on the model of your Intertek 3177973 remote control unit. Consult the manual for the specific steps and precautions before pairing or syncing on your remote control unit.
1/14/2023 1:25:14 AM •
Home
Answered
on Jan 14, 2023
How do I accurately calibrate my digital scale that is a manlloro 200g made in China
To calibrate a digital scale, you will need to follow these steps:
- Find a weight that you know the exact weight of, such as a coin or a small weight. This weight will be used to calibrate the scale.
- Place the weight on the scale and wait for the scale to stabilize.
- Check the weight displayed on the scale. If it is not accurate, use the scale's calibration function to adjust the scale to the correct weight.
- To calibrate the scale using the calibration function, follow the instructions in the user manual for your specific scale. The process may vary depending on the make and model of the scale.
- Once the scale is calibrated, remove the weight and test the scale by weighing an object of known weight. If the scale displays the correct weight, the scale is properly calibrated. If the scale is still not accurate, you may need to repeat the calibration process or consult the user manual for further instructions.
I hope this helps! If you have any further questions, don't hesitate to ask.
1/8/2023 11:03:22 PM •
Home
Answered
on Jan 08, 2023
Are there any nursery rhymes music boxes?
have seen some nursery rhymes musical figurines http://www.themusicboxcompany.com/baby_children.htm#nurseryrhymes scroll down to nursery rhymes
1/6/2023 5:51:58 AM •
Home
Answered
on Jan 06, 2023
Weird issues with tankless water heater
It sounds like you are experiencing some unusual behavior with your tankless water heater. There could be a few different factors contributing to these issues.
One possibility is that the temperature sensing and control system on your tankless water heater is not working properly. This could be caused by a problem with the thermostat or other components of the temperature control system.
Another possibility is that there is an issue with the flow rate of the hot water being delivered to your shower. If the flow rate is too low, the water may not have enough time to heat up properly, resulting in cold water being mixed with hot water.
It's also possible that there is a problem with the plumbing in your house, such as a blockage or a leak, which is causing the water temperature to fluctuate.
To troubleshoot these issues, you may want to start by checking the thermostat and control system on your tankless water heater to make sure it is functioning properly. If the thermostat appears to be working correctly, you may want to try adjusting the flow rate of the hot water to see if that helps stabilize the water temperature. If these steps do not resolve the problem, it may be necessary to call a plumber to diagnose and fix the issue.
12/27/2022 4:29:02 PM •
Home
Answered
on Dec 27, 2022
Water dripping from the Shower Head of a Mira Elite QT when unit is off
It sounds like you may have a problem with the internal plumbing of your shower unit. The filter at the bottom of the unit may be clogged, or there may be a problem with the valve that controls the flow of water to the shower head.
To troubleshoot this issue, you could try the following steps:
- Check the filter at the bottom of the unit for any debris or clogs. If the filter is dirty, clean it out and see if that helps stop the dripping.
- If the filter is clean, try shutting off the water supply to the shower and then opening the valve that controls the flow of water to the shower head. This will allow any excess water to drain out of the unit.
- If the dripping persists after these steps, it may be necessary to call a plumber to diagnose and fix the problem. It's possible that there is a problem with the internal plumbing of the unit that will require professional repair.
12/27/2022 4:25:40 PM •
Home
Answered
on Dec 27, 2022
Can you solder the wires for a splice on a oven temperature sensor that has a melted connector?
Yes, it is possible to solder the wires for a splice on a oven temperature sensor that has a melted connector. Soldering is a common method for making electrical connections, and it can be used to repair a melted connector on a oven temperature sensor.
To solder the wires for a splice on a oven temperature sensor, you will need the following tools and materials:
- Soldering iron
- Solder wire
- Wire stripper
- Heat-shrink tubing (optional)
Here is a general outline of the process:
- Gather your tools and materials.
- Cut off the melted connector from the oven temperature sensor.
- Strip the insulation from the ends of the wires.
- Twist the wire strands together to create a solid connection.
- Heat the soldering iron and apply a small amount of solder to the wire connection.
- Allow the solder to cool, and then apply heat-shrink tubing over the connection (optional).
It is important to follow proper safety precautions when soldering, including wearing protective eyewear and working in a well-ventilated area. If you are not comfortable soldering the wires yourself, you may want to seek the assistance of a qualified technician or engineer.
12/27/2022 2:33:41 PM •
Home
Answered
on Dec 27, 2022
What do vessels oil do and how ?
The
oil vessels that you see in the harbor are specially built for carrying oil. They transport oil from one place to another. These are large ships that can carry large amounts of oil. They also have a lot of space for cargo. Oil vessels can run on steam engines or on diesel engines.
Oil and gas tankers are a type of vessel used to transport large quantities of oil and diluted molasses. They are used to transport oil and gas from one region to another.
Rus Marine Oil supplies premium quality Marine Lubrication Oil at a reasonable price in all ports of the Far East, southern Russia, and the Baltic states. Call us right now!
12/15/2022 10:26:28 AM •
Home
Answered
on Dec 15, 2022
