If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
View the site by desktop or web view on mobile devices to see the "search box". Type in the brand name of your set in search box; to get gathered the related posts.
Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
SOURCE: Proscan PS35123-horizontal line only,sound ok
You have whats called a verticle swep falure. Its probably just the verticle output IC but if you dont know much about soldering or circuit troubleshooting ,you should leave this to the pros. Theres way to much Hi voltage inside these sets to twiddle around inside them. Also there are no consumer serviceable parts inside these sets as well, as they are all solid state, and my advice is spend a few bucks and get a pro to do this job for ya, as it can, and will, kill ya if your not careful.. Is it worth saving a few bucks??? Naawww Call a pro.. Good Luck
SOURCE: horizontal green lines the whole length and width of the screen
Hey, I had the same problem with blue and red lines and this post helped me bigtime ! Just adjust the color your having problems with. Best Solutionposted on Sep 12, 2006By maddogmic Rank: Not rated Rating: 100%, 1 votes I had the same problem with my sony KP-57ws500 rear projection tv. To solve this problem all you need is a flat and phillips screwdriver. Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the
SOURCE: PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a
built-in tuner (called HDTV, digital, or ATSC tuners) that can receive
high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an
external tuner (or cable or satellite box) to watch high-definition
programming. External over-the-air HDTV tuners currently cost at least
$150.
SOURCE: hitachi projection tv digital channel problem
yes i have same tv it has no digital tuner >( you must get a converter box
