20 Most Recent Hitachi C21-F200 21" TV Questions & Answers
manual
manual
CHANGE LANGUAGE
you can set the laguage on the remote control.go to menu and try to find the language set up menu...
1/20/2015 10:11:32 PM • Hitachi C21-F200... • Answered on Jan 20, 2015
Remote model number
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. If you wish to get more details about this, try the sites linked here. It has set-up code list, and set-up procedure to many popular brand universal remote controls. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/
1/1/2014 6:32:46 AM • Hitachi C21-F200... • Answered on Jan 01, 2014
Hitachi C21 model.The colours on screen have got scrambled.
It sounds like something has left a strong magnetic field on the face of the picture tube, and that's causing the colour distortion. The electron beams from the tube's colour guns are hitting the wrong spots on the face. There is a degaussing circuit in the TV that tries to neutralise such fields every time the set turns on. Sometimes electrical equipment (particularly motorised appliances like a vacuum sweeper) operating too close to the TV can leave a field too strong for the degaussing circuit to cope with. Or a failed part in the circuit may have made it inoperative.
A hand-held degaussing coil can be used to remove the field. You can purchase one online, or call a TV service technician. It used to be a standard tool to carry.
Another possibility is that the tube has been damaged. There is a very thin metal mesh screen called the shadow mask behind the face of the tube. If this mask has been warped by a strong magnetic field or a mechanical shock (if the set was dropped, for instance), you will see the same colour distortion. In this case, however, there is no repair other than tube replacement. And that is likely to cost more than a new set with parts and labour.
1/2/2011 2:37:42 AM • Hitachi C21-F200... • Answered on Jan 02, 2011
I am attaching a digital
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
1/1/2011 10:53:51 PM • Hitachi C21-F200... • Answered on Jan 01, 2011
2answers
Hitachi C21-F200 remote control
There are a lot of local service centers in the city, I don't know where you can find it exactly, why don't you check the yellow pages? The remote problem is not one that would cost a lot and you don't need to go the authorised Hitachi Service.
11/17/2008 4:06:48 AM • Hitachi C21-F200... • Answered on Nov 17, 2008
2answers
Can't highlight or select digital channels to autoscan on hitachi 51f59a
It sounds like you're experiencing an issue with your Hitachi 51F59A TV not allowing you to select or highlight digital channels for autoscan. Here are a few things you can try to resolve the issue:
  1. Check the TV's settings: Make sure the TV is set to the correct input (such as "TV" or "antenna") and that the channel search or autoscan feature is turned on. Consult the TV's manual or the on-screen menu for instructions on how to access these settings.
  2. Check the TV's connection: Make sure the TV is properly connected to a digital antenna or cable box. Also, check that the cables are securely connected and not damaged.
  3. Check for a firmware update: Sometimes a firmware update can resolve issues like this. Check the TV's manual or the manufacturer's website for instructions on how to check for and install firmware updates.
  4. Try a factory reset: If the above steps don't work, you can try performing a factory reset on the TV. This will restore the TV to its original settings and may resolve any issues with the channel search or autoscan feature. Consult the TV's manual or the on-screen menu for instructions on how to perform a factory reset.
  5. Check for a hardware issue: If none of the above solutions work, the issue could be caused by a hardware problem with the TV. In this case, you may need to contact the manufacturer or a repair professional to have the TV serviced.
3/18/2023 8:43:58 AM • Hitachi... • Answered on Mar 18, 2023
Hitachi 65r8 no backlighting
It's the strips themselves that are bad
2/27/2023 7:32:45 PM • Hitachi... • Answered on Feb 27, 2023
Hitachi L40A105 closed caption
Do you have the captions set for Analog or Digital captions? The advanced setting is only available for digital captions. See https://www.manualslib.com/manual/520286/Hitachi-Alpha-L40a105.html?page=19#manual . I hope this helps. Cindy Wells
1/26/2023 11:49:34 PM • Hitachi... • Answered on Jan 26, 2023
HITACHI AX-M71 MUSIC SYSTEM REMOTE
1/23/2023 11:33:19 PM • Hitachi... • Answered on Jan 23, 2023
8.5tr ductable hitachi in remote red light blinking continues what the reason
count the blinks and refer it from user manual trouble shoot section , you will find the reason
1/19/2023 7:29:04 PM • Hitachi... • Answered on Jan 19, 2023
Hitachi tv black screen ?
but nothing else If your Hitachi television has sound but a black screen, it is likely that either the bulb or the inverter has gone bad. The inverter is a part of the backlight system. If the inverter is not functioning, the backlight will not work and the television will be dark. You should check to see if the bulb needs to be replaced first. If the bulb is working and the inverter doesn't turn on, then you may need to have a technician take a look at the television.
1/6/2023 3:08:36 PM • Hitachi... • Answered on Jan 06, 2023
2answers
I have a Hitachi lcd model 50A3. Won't come on and has the blue light instead of red
Hello, more than likely the set has bad back lights, a very common issue with these sets...sorry. Techman 57
11/5/2022 4:35:45 AM • Hitachi... • Answered on Nov 05, 2022
2answers
How do I get the language settings back to English on My Hitachi TV Please ?
https://www.askmefast.com/How_do_i_change_the_language_to_english_on_my_hitachi_50hxt16u_please-qna7526359.html#q4753135
11/5/2022 4:28:04 AM • Hitachi... • Answered on Nov 05, 2022
My Hitachi 65F59A has a blue tint picture all the time? How do I Resolve this? Thank you
Hi, you would need to use your display settings to change the tint. There might be a tint or a hue option that you can press with the display settings. Thank you.
10/7/2022 6:57:00 PM • Hitachi... • Answered on Oct 07, 2022
Toshiba 55HT1U flash of blue when powering up - no other sign of life
An 11 year set isn't worth repairing, time for a new TV
9/13/2022 11:33:41 PM • Hitachi... • Answered on Sep 13, 2022
HITACHI 55HK6100U SMART TV REMOTE CONTROL CAUSES INTERFERENCE ON PICTURE
There is a post about this issue on the AVI blog. There are several people that have had the issue. No one claims a fix for it though. Seems to be related to HDMI cables and how close they are to the remote extender runs.
8/23/2022 2:15:45 AM • Hitachi... • Answered on Aug 23, 2022
Hitachi C21-F200 21" TV Logo
8 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
am attaching digital
  • Televison & Video
