20 Most Recent Hitachi 65F59 65" HDTV Questions & Answers
Convergence problem, find a honest TV tech.
Hitachi 65F59... | Answered on Nov 14, 2013
SOUNDS LIKE CONVERGENCE...GREAT TV...ABOUT A $400 REPAIR
Hitachi 65F59... | Answered on Nov 10, 2013
I think you will find it is not available or sold apart from the two inner screens.
A option is to find and buy a piece of similar plexi-glass as that is only a anti glare protective screen.
Measure it carefully and do some research.
Hitachi 65F59... | Answered on Jun 08, 2012
If it's a projection tv, your bulb is about to die.
Hitachi 65F59... | Answered on Apr 24, 2012
Remove the Front Bootom Panel Then under the screen is serveral screws holding Screen on remove them and Screen Lifts Up and out.
Hitachi 65F59... | Answered on Oct 18, 2011
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Hitachi 65F59... | Answered on Sep 07, 2011
it could be a wire plug not seated properly on the DCU. I would inspect the wire connections to insure they are al seated properly
Hitachi 65F59... | Answered on Jul 16, 2011
for the crack, you can buy a new screen from www.TvRepairKits.com though it will cost a little over $100 because it will cost about $100 to ship. as for the drown, i don't know how to fix it. to remove the screens just pop off the part covering the edges of the screen
Hitachi 65F59... | Answered on Mar 19, 2011
there is a mirror inside the projector box, contact www.partstore.com or andrewselectronics.com. you will need a complete model number when you research the part number for the mirror.
Hitachi 65F59... | Answered on Nov 03, 2010
hi
forget the whole thing !!! Sorry
Hitachi 65F59... | Answered on Sep 30, 2010
You have several choices:
1. GOOGLE THE MODEL NUMBER WITH THE WORDS: REPLACEMENT SCREENS
2. You can contact ANDREWS ELECTRONICS IN Los Angeles; they are the largest OEM parts dealer in the United States.
Be aware---most of the Hitachi units use a inner and outer screen and most are only sold as a pair.
These, if available are not cheap---a guess would be over 200 plus for both screens.
Do some research with GOOGLE AND SEE WHAT YOU CAN FIND.
IF this help told you something you did not know, rate this solution as very helpful as I do this here for FREE.
If you have any questions or need advice let me know by commenting here.
REGARDS, SD TECH
Hitachi 65F59... | Answered on Aug 14, 2010
Remove front speaker grill then remove screws on lower part of front screen and few screws on either sides and on top part from rear and take off front screen frame.
In front frame, remove screws on all 4 sides and take off metal bars that holds the front screen layers intact. Put new screen and fix things in reverse order.
I would recommend to download service manual copy of Hitachi 65F59A from HERE for small fee that has detailed exploded views about all above said procedure.
Hope these info will help you.
Thanks.
Hitachi 65F59... | Answered on May 23, 2010
Hitachi 65F59 65" HDTV Logo
49 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
cable in area
  • Televison & Video
