20 Most Recent Hitachi 51GWX20B 51" Rear Projection Television Questions & Answers
Suddenly color out of whack and words shadow each
You have a convergence problem. If you are handy, you may be able to repair this. The signal module will need reworked. The best repair for you, or some one you know, who is an electronic servicer can get help. Please see the website www.TvRepairKits.com. You will find the best repair kit. I have used this website to repair a few of the Hitachi Projection TVs. The instructions, and parts,, along with photos, will be very, very helpful. Have your TV model number close by, as you search this website. Thanks for asking and show a few hands of support!
3/6/2011 5:39:13 AM • Hitachi 51GWX20B... • Answered on Mar 06, 2011
The left side of the picture is distorted with a
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
1/12/2011 6:28:23 PM • Hitachi 51GWX20B... • Answered on Jan 12, 2011
Lcd looks a red wave line it look like it's out
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
5/30/2010 5:44:54 AM • Hitachi 51GWX20B... • Answered on May 30, 2010
LCD rear projection tv has
This sound like a Bad Optical Block. If this is a Hitachi, and it is less than 3yrs old, I would try to see if Hitachi will help with the repairs. You would still need to get a local authorized repais facility out to comfirm it is the Opical Block. They should be able to help with that as well.
Hope this helps,
Skyassoc
6/29/2009 2:20:16 AM • Hitachi 51GWX20B... • Answered on Jun 29, 2009
Red and Green have separated in double image.
You have a defective CONVERGENCE IC. Most TV use 2 identical STK IC & both has to be replaced at the same time. If you are not a technician I don't recommend doing it yourself. There is a lot of desoldering to remove the chips with 16 or more pins- and soldering the new ones.
Good luck! Astrotech
5/28/2009 12:49:00 AM • Hitachi 51GWX20B... • Answered on May 28, 2009
Hitachi 51gwx20b service code
There is not a Service code to Enter into convergence on this set , on convergence board there is a switch on the very front of board WITH set on press and hold 3secs you should see convergence Pattern Appear after you release button. From the Front of TV remove Bottom cover then you will be able to see whole chassis,and the Little Blue contact switch.on same board you replaced ICs.
1/16/2009 11:01:40 PM • Hitachi 51GWX20B... • Answered on Jan 16, 2009
51GWX20B Getting very dim
Bad capacitors in power supply circuit.47uf 250v
1/10/2009 11:45:29 AM • Hitachi 51GWX20B... • Answered on Jan 10, 2009
Hitachi 51GWX20B rear projection with sound no picture
Audio output chip.
1/10/2009 11:44:12 AM • Hitachi 51GWX20B... • Answered on Jan 10, 2009
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
1/10/2009 11:43:02 AM • Hitachi 51GWX20B... • Answered on Jan 10, 2009
On and off
Replace Your STK ICs.STK392-110s use 180s if 020s use 040s if 560 or 570 use the same.
1/10/2009 7:20:59 AM • Hitachi 51GWX20B... • Answered on Jan 10, 2009
Double image
Problem seems in convergence out section.
TV needs Convergence Out ICs replacement.
If you have TV repair experience and know good soldering work then you can give it try OR get help of qualified TV tech to fix it.
If you need further help, let me know.
12/30/2008 6:20:47 PM • Hitachi 51GWX20B... • Answered on Dec 30, 2008
2answers
Hitachi 51" projection tv has sound but no picture...help!
i founfd this, it could be the problem. Symptom: NO VIDEO Cause: Found L306 was open. B+ to pins 21,22 of PFC2 at the FC. find L306, will be hard to find with all the boards, but L306 is a coil. if you can find it use a multimeter to see if it's open. 450 sound slightly high but if you have a service call or pickup & delivery it might be right. hopefully you find the coil bad. good luck.
11/27/2008 11:53:13 AM • Hitachi 51GWX20B... • Answered on Nov 27, 2008
Hitachi projection tv model 3 51gwx208
Do you mean that at the top of the picture, the red color has shifted downward, bowed towards the center? If that is what you see, one color suddenly bows toward the center on any side of the picture, then it means that one of your convergence IC's has burned out and needs to be replaced. It is a good idea to go ahead and replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's and realigned the convergence circuits in a projection TV then allow a qualified tech to handle it for you.
7/2/2008 8:05:12 PM • Hitachi 51GWX20B... • Answered on Jul 02, 2008
Hitachi M-171 VCR Turns on, but won't operate, tape inside,
Hi, Please call the Hitachi customer service number to ask them to send the VCR manual to you via email. The number is 1 (800) 448-2244 . Also, please double check that you've already pressed the eject button on your vcr to help attempt to get the tape out. Thank you.
5/20/2022 12:40:13 AM • Hitachi... • Answered on May 20, 2022
Hitachi 42HDM12A not changing modes all the time
Are you talking about inputs can't be changed?
3/23/2022 1:43:28 PM • Hitachi... • Answered on Mar 23, 2022
Hitachi 51GWX20B 51" Rear Projection Television Logo
15 questions posted
Top Hitachi Televison & Video Experts
Ekse
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
left side picture distorted
  • Televison & Video
