Try to get your needle loose and out. Check for a mess of thread. Once for sure everything is out replace the needle and attempt to move the hand wheel. If it will turn you're in good shape. If it doesn't turn try once to slightly force it to turn. If you notice it to turn a little distance then stop like a crash you will need to have it timed by a pro.
SOURCE: Hand Wheel
There is a smaller wheel in the center of the big wheel. This has to be tightened in order for the needle to operate. This smaller wheel is needing to be in the loosened state to wind the bobbin. The needle should not go up & down then. Just hold the outside wheel & tighten the inner wheel. This should solve your problem. Hey, just wondering if I could possibly get a copy of your manual, as I lost mine for this model. I would really appreciate it! My email is [email protected] Thanks & Good Luck
SOURCE: balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
SOURCE: hand wheel loose
In the middle of the stop motion screw wheel there is a screw, undo the screw and unscrew the stop motion wheel all the way off, you will now see a three pronged washer, take it off and put it in a different position, put the stop motion wheel back on and just tighten finger tight, tighten the small screw all the way, now loosen the stop motion wheel and press on the foot control gently, the balance wheel should move with moving the machine, if the machine turns then start over again, you can put the three pronged washer upside down if you wish.
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
SOURCE: baby lock quest, blq2 bobbin problem
Concerning the Babylock Quest when using the reverse option I seem to be reading a few somplaits what is the best way to reverse without causing and adverse problems?
thanks
sewingcindy
