20 Most Recent Baby Lock Ellure Questions & Answers
2answers
I keep getting the error message
the problem of your machine is your bobbin, you should adjust it.
11/1/2021 12:23:32 AM • Baby Lock Ellure • Answered on Nov 01, 2021
2answers
On my brother PE770, the "press the needle
it's possible that there is something wrong with the needle bar or the screen, it would be good to have the machine checked.
11/15/2020 12:08:30 AM • Baby Lock Ellure • Answered on Nov 15, 2020
My babylock ellure plus sewing machine keeps
Definitely a problem to be adjusted by a qualified Babylock technician
6/27/2019 10:39:00 PM • Baby Lock Ellure • Answered on Jun 27, 2019
Need service manual for baby ellure ESL.
you can try contacting babylock and see if they can help you
5/27/2019 6:22:29 PM • Baby Lock Ellure • Answered on May 27, 2019
How di i turn off speed controller mode
In the Setup pages. Power on your machine. Press the Settings tab. Arrow (>) through to Width Control ON:OFF. Select ON
3/27/2019 3:47:13 AM • Baby Lock Ellure • Answered on Mar 27, 2019
2answers
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
4/5/2018 7:39:03 AM • Baby Lock Ellure • Answered on Apr 05, 2018
2answers
I am receiving a message
https://www.babylock.com/support/contact 1-800-313-4110 Toll free Customer Support phone number in the United States.
2/9/2018 6:13:39 PM • Baby Lock Ellure • Answered on Feb 09, 2018
Bobbin not winding. The
Is the metal spool just spinning in the middle of the bobbin because the hole is not a tight fit? I would check my manual for the correct bobbin & then purchase using the specific part number (e.g. SA156). I found this number in the list of "included accessories" for my machine. There will be a part number besides the name.
10/10/2017 9:11:42 PM • Baby Lock Ellure • Answered on Oct 10, 2017
2answers
Tension on upper thread?
It sounds like the machine needs to be timed, seek out a sewing machine repair shop for this service.
6/8/2017 2:12:09 AM • Baby Lock Ellure • Answered on Jun 08, 2017
3answers
Operating manual for Mini Lock FR 850 Serger
try at www.ifixmachines.com
1/31/2017 8:15:14 PM • Baby Lock Ellure • Answered on Jan 31, 2017
My top thread keeps catching and bunching up under the needle plate.
  • Raise presser foot when upper threading.
  • Thread normally through all guides
  • Lower presser foot
  • Thread needle, leaving a 6" thread tail
  • Raise foot and gently pull thread (no tension)
  • Lower foot & gently pull thread (you'll feel resistance)
  • Delint upper tension with Compressed Dry Canned Lint Remover ie: Computer Quality. Be sure no thread is in machine and foot is up so tension is released
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
6/1/2016 6:11:55 PM • Baby Lock Ellure • Answered on Jun 01, 2016
WHY??!! *Check if thread is entangled. Check if needle is bent. So far as I can tell everything is fine, used new bobbin, new needle, still getting error. How do I know if the motor has become locked
Time to take it in and have the repair tech service & clean upper tension assembly. When you clip/ change threads be sure not to pull the thread back out of tension assembly. Snip thread at spool, raise foot to release tension and then pull the short thread out from the needle. The Automatic tension is very delicate and pulling thread out backwards can cause thread/lint build up and problems like your having. Sal the Sewing Gal
6/1/2016 5:23:39 PM • Baby Lock Ellure • Answered on Jun 01, 2016
2answers
What type of file does babylock accept other than
Babylock only reads PES.
2/14/2016 4:39:10 PM • Baby Lock Ellure • Answered on Feb 14, 2016
3answers
I have a baby lock ellure model ESL and the LCD display went out. How do i fix it
Sorry, you will have to take it to a Brother/ Babylock dealer for repair.
7/6/2015 6:58:56 PM • Baby Lock Ellure • Answered on Jul 06, 2015
Card reader will not accept card
Turn it over.
3/7/2015 3:45:38 AM • Baby Lock Ellure • Answered on Mar 07, 2015
Machine stops while sewing elegante 2
Check to make sure there is plenty of thread on the bobbin.
3/7/2015 3:43:42 AM • Baby Lock Ellure • Answered on Mar 07, 2015
Bobbin thread not catching
Rethread, paying particular attention to the take-up lever. Try a new needle.
3/7/2015 3:40:30 AM • Baby Lock Ellure • Answered on Mar 07, 2015
Sewing Machines Logo
300 questions posted
Popular Products
Top Baby Lock Sewing Machines Experts
mark woodring
mark woodring
Ruth summersides
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Baby Lock Sewing Machines
Most Popular Question
keep decorative stitch consistant
  • Sewing Machines
