Gill: I have the same problem as Sheillz (Sept.15, 2009)
I
have installed a color ink printer and both black and color lights of cartriges
are still blinking and I cannot print anything at all. Not even a test
page.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head
install both cartridges on ur printer n check ur blinking light on ur printer
that will work only if u r too lucky other wise u have to purchase a one cartridge.
..."Open the ink supply andgently move the ink cartridges to the left.
Then reach in to the rightside and you'll find a small (1/2 x 1 inch)
sponge. Push it down andoff/on the machine. try it now. or ...go to
where I found out more than I should know about Canon's and where I got
my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good
luck.
The light you describe is the ink light. When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge. Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too. This printer will not work without both ink cartridges installed and full. You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
if you are having issues after installing the new cartridges , then perform the following steps.
unplug the power adapter and remove both the cartridges and then power on the printer , look for the power light. if it does not blink then . install the black cartridge first and then try to print , if it prints fine its ok. then remove the black cartridge and then put the color one in and then try printing or copying .
if it doesnot print with any either black/ color then you have to replace that particular caratridge..
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light
Introduction
The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed.
Instructions
The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2.
NOTE:
The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
Figure 1: Cartridge status iconsIcon/DrawingProblem identified by the symbolSolution
The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed.
1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
3. Check to make sure the color cartridge is appropriate for the printer.
4. If the problem persists, replace the color cartridge.
The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective.
1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
3. Check to make sure the black cartridge is appropriate for the printer.
4. If the problem persists, replace the black cartridge.
The color print cartridge is running low on ink.
Replace the color print cartridge with a new color print cartridge.
The black print cartridge is running low on ink.
Replace the black print cartridge with a new black print cartridge.
None. The print cartridges are working correctly.
Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
Open the Access Cover and hold it open.
Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
Install the Access Cover by following the steps below:
Align the hinges on the Access Cover with the hinge pins on the printer.
Push down firmly on the Access Cover until the hinges snap into position.
Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2.
Figure 2: Pressure points
Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5.
Figure 3: Squeezing the pressure points
If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
