Question about Canon PIXMA MP240 All-In-One InkJet Printer
Will not print. color ink cartridge light keeps
My printer will not print. The color ink cartridge light keeps blinking. I just put a new black ink cartridge in, the color cartridge is empty but still in place. Everything is lined up properly. I have rebooted the computer, I have pressed every button there is to press, When the color ink light is not blinking, then the alarm light is blinking. It blinks 8 times and then goes off. So back to the beginning. After I turn the power on, just the green power light is on. So I click Start and then click notepad and type out a few words of script. Then I click File and click Print. After I do this, the color ink light starts blinking and a message comes up. On the heading it reads "Canon MP 240 Series Printer-USB001". The message reads "The ink cartridge has been installed or replaced. If the printout contains misaligned lines or is not satisfactory after the installation or replacement, refer to the User`s guide, ( which has absolutely nothing at all in it for troubleshooting ). So I clicked on " OK " and first the color ink light started blinking and then the amber alarm light would blink 8 times, which apparently means something ? Then another error message would come up on the screen that read, " Service Error 5200 ", " Cancel printing and turn the printer off and then on again. If this doesn`t clear the error, see the printer manual for more details". Ha ha !! There is absolutely nothing in the manual for troubleshooting. Can someone PLEASE HELP ME !!!
Posted by steav1 on
Judith Morris-Mattes
    Scholar:
  • 66 Answers
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Posted on Oct 21, 2009
Anonymous
    New Friend:
Replace the color cartrige and it will work fine. Cannon SUCKS ! !
Posted on Oct 10, 2010
Anonymous
  • 855 Answers
It sounds as if you may of pukked out the color cartridge. If that is the case you need to buy a new one. Since the color ink is empty the printer can not align cartridges because nothing is printing in color so sensors can not detect the ink to align and sends a error message.
Ravi Kanth
    Problem Solver:
  • 10 Answers
Try the option "print all text as black" in print properties.
Anonymous
    President:
  • 787 Answers
Service Error 5200 is "print head temperature rise error".This mean your color cartridge is overheating.You need to replace it to continue printing.
The green power button blinks continuously and the printer will not print any type of job. The last job printed was very clear so I don't think I need a new ink cartridge. The status of the printer shows...
ya u need now inkjet cartridge or ur printers card dead 1st chack put black cartridge in ur printers and color cartridge out then see green light blinks if blinks black cartridge out and color cartridge put in the printers then u know thanls
Jul 03, 2010 | HP DeskJet 3940 InkJet Photo Printer
I just put new cartridges in my printer, won't print
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i. Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii. The Cartridge electronic panel is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning. This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
Replaced only black -- will it work without a new colored ink cartridge? Resume light keeps blinking.
hi both of your inks need to be installed with ink in if there is one with no ink like the color the printer will not work, you will have to wait until you have the color.
May 20, 2009 | HP DeskJet 648c InkJet Printer
Ink light blinking hp920c
Yes, sorry to say. The system uses all carts even to print in black.
Feb 13, 2009 | HP DeskJet 920c InkJet Printer
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Color ink cartridge
Yes you need to have both carts in the printer
Jun 02, 2008 | Lexmark X2500 All-In-One Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
2,676 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
