You want to start print or copy the start bottom is red light not green light so red light start bottom the machine is not ready
SOURCE: PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
Hey zrscott388, did you end up replacing the bulb and did that fix it? My Z1 is doing the same thing. I hate to spend 300-400 on a bulb and it doesn't work. The Z5 is going for 1100 new on Ebay. I rather do that than waste money. Please let me know.
SOURCE: Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
SOURCE: Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at [email protected]
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
SOURCE: Printing a Booklet on a Ricoh Africio 3260C
first you need to use the RPCS printer driver supplied by ricoh. Second then go to printer properties box and then select the tab for finishing, you should then see the options for booklet printing, if the option are not there you have to add the finisher in the printer driver as an option
http://www.websitetoolbox.com/mb/copierquestions
Hi ahmed , I want to help you with your question, but I need more information from you.
Please call Customer Service For Help & Support Call 1 8O5*465*751O Toll Free 24x7///
