Question about Ricoh Office Equipment & Supplies
SOURCE: copies and faxes come out with 5 inch black area over whole page
Does this same thing happen if you just print a report out of it?
Here's the logic behind this.
If it happens on scanning or copying, but not on printing that's a problem with the scanning section.
If it happens on everything (scanning, printing etc) that's a problem with in the printer controls.
Usually on lasers, if it's printing related, the first thing to do is change the toner.
If the imaging drum (which is part of the toner cartridge) is damaged, it will leave lines down the page.
This is a fairly common problem on refilled toners.
If you have changed the toner, and it still does it, it's a different problem.
Posted on Aug 11, 2008
SOURCE: Photocopies with black lines from top to bottom.
Your leading edge erase margin is adjusted out too far. It can be adjusted with a manual.
Posted on Mar 01, 2009
SOURCE: black dots on printouts
there is probably something on a drum, fuser roller, transfer roller, or primary roller. usually an easy fix for a copier tech, probably not for someone with no experience.
Posted on Apr 29, 2009
SOURCE: Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Posted on Aug 21, 2009
SOURCE: functional problem sc 390 on ricoh photocopier,
SC 390 on an Aficio 1018 will most likely be a bad TD (toner density) sensor, if you've already replaced the drum and developer. (One thing to check quickly though is to pull the PCU out and reinstall it, just to make sure that connection isn't the problem.)
You can either replace the TD sensor by itself, or replace the DV unit (which probably won't be much more expensive). But either way, you'll need to install new developer when you replace the parts.
Posted on Aug 24, 2011
Jul 29, 2015 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Dec 04, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Jun 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Sep 18, 2010 | Ricoh Aficio 2027 Black and White Copier
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
Mar 15, 2010 | Office Equipment & Supplies
Jun 01, 2009 | Ricoh Aficio 350e Printer
Feb 25, 2009 | Ricoh Aficio 450 Copier
Feb 17, 2009 | Ricoh Office Equipment & Supplies
42 people viewed this question
