20 Most Recent Ricoh Aficio 1232C Color Copier Questions & Answers
CTRL - ALT - DELETE should show it in Tasks. Delete it from there. Reboot computer and Copier, try again. You may need to reinstall software and drivers.
Ricoh Aficio... • Answered on May 01, 2021
Download Twain Driver from ricoh site and you can use any softwere that suports twain scaning i use microsoft scan that comes with office 2003
Ricoh Aficio... • Answered on Apr 18, 2018
We are assuming that you are talking about Error Code SC 221
This code is a Scan length detection problem.
1.Disconnected Sychronization Detector
2.Bad LD-Unit/BICU Board
SOLUTION: Replace the Laser Diode & Laser Sync detect board
Hope helps (remember to rating this free answer).
Ricoh Aficio... • Answered on Mar 27, 2015
you need to adjust the lead edge trim press yellow C and 107 and press and hold red C button then go to copy SP select 2 drum then look for trim adjust and then select front then change values up and down until you get the correct registration. you can do a test copy while on SP mode by pressing copy window.
Ricoh Aficio... • Answered on Sep 30, 2014
there may b ur optics dirty
or the cleaning blade faulty to clarify the problem just take out a print of counter if line occurs then ur cleaning blade faulty if counter is clear then claen the optics or scanner mirrors
Ricoh Aficio... • Answered on Sep 24, 2014
Have you just bought this 2nd hand? if its flashing in the bottom left corner? can you still print to it?
Ricoh Aficio... • Answered on Sep 19, 2014
SC822 is a hard drive error. that machine has 2 installed and should be replaced as a pair. it's hard to determin which one has failed.
Ricoh Aficio... • Answered on Jul 09, 2014
need to clean the optics for sc-172
Ricoh Aficio... • Answered on Apr 23, 2014
check your copier sensors that read toner density in your aficio 1232C
Ricoh Aficio... • Answered on Apr 14, 2014
SC 792 :Finisher error .The machine does not recognize the finisher , but recognizes the relay unit .Possible causes :Defective connectordefective cable incorrect installation
Ricoh Aficio... • Answered on Apr 09, 2014
check da chip on da toinner
Ricoh Aficio... • Answered on Apr 06, 2014
CHECK ALL THE SENSOR WHERE THE PAPER PATH GOING TO EXIT
Ricoh Aficio... • Answered on Feb 10, 2014
Ricoh Aficio 1232C Color Copier Logo
Popular Tags
113 questions posted
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
go
  • Office Equipment & Supplies
