Purchased a Fisher CA-9025 Stereo Amp. and a Sony CDP-CX335 300 disc player Any idea where I could find an owners manuals most important is the amp. Totally new to this.
Thanks
I searched and only saw Service Manuals as you stated. Not sure what information you need.
I saw several youtube videos that might give you contacts to email for assistance. I also saw what appear to be the same model for sale on ebay so you might also try emailing vendors as well.
When it comes to vintage equipment, manuals are hard to find as paper gets trashed and the companies that are no longer in business don't have web sites - not sure how you could get documents that you want without luck. That seems to be a model that is still being used from the web discussions I saw, so maybe consider posting or contacting blogs that have it mentioned.
FIXYA is a free service where answers are provided for free by users just like you, so if you have success with your question or know the answer to someone else's, please post it.
First off you dont look or try to e-mail when you go to their sites HELP NUMBER +1 833 272 0777they have contact info also some have manuals that can be downloaded from their sites also their are 100s of sites with manual if you did a search
These units use STK amp pac ICs (large black part attached to the rear heatsink). In many cases, this IC is defective. It is possible that there is a problem with the voltage regulator circuit, but that is less likely. This IC needs to be replaced. Expect to pay in the $50 range (or more) for the part.
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Lets try the simple stuff first. Check to be sure that the tape monitor switch is not engaged. Since youare getting some sound, it appears that the signal path is being interrupted. It is possible that the output transistors have failed (open), but that is extremely rare. Check the tape monitor switch and update this with your results.
For those who accidently put thier CA-9025 in standby mode by hitting the timer button and no longer have the remote, I figured out how to turn them back on.
Turn on the power button and press and hold the Tuner button for at least 10 seconds. it should come back on :) Hope that helps.
