Hello, Carole -
It means it is time to descale (remove the calcium build up) your coffee maker.
Look in the owner's manual for your coffee maker and follow the directions for descaling it.
Is your machine a Bosch Tassimo My Way coffee maker?
If you do not have the owner's manual for your coffee maker, click or tap on Comment and add the maker name, model name and model number there, so I or someone else can try to find a free manual for you to download.
Best wishes.
SOURCE: On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
SOURCE: coffee machine leaking
You say it is dropped on the front side of the tv but how come it come from the back of the tv. It must be spreaded. While coming to the back side hope it didnt damaged vital elements of the tv. Anyway don't open it until you clean the internal organs. Later need to be opened under the supervision of a technical person.
