It says the USB cable is not working when it is okay
Just happend, today, yesterday was ok, same setup?
or just got this from a garage sale and ...
or found it or barrowed it or >? tell the story please.
no PC stated
no OS stated (windows what?)
to run a printer on USB the printer needs to be reset first.
to USB mode, this is covered in the manual, lost that?
the USB port needs to be working , try them all/?
the HP software needs to be loaded too.
omg its 14 years old today. click software and then click change.
then pick your UNSTATED OS,in the huge list of operating systems this printer supports even up to w10
https://support.hp.com/us-en/product/hp-laserjet-4350-printer-series/412160/model/412162/manuals
SOURCE: Printer problem
First remove the control panel from the machine and make sure that the cable is seated well to the panel and the control board. If they are remove both cable ends and reseat them.
SOURCE: Laser Jet 4 plus can't print with USB?
1.check the cable compatibility
2.install the driver HP laser jetIII
SOURCE: I just purchased a used
You have installed the software and driver? for you version of the computer OS?
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25475&submit.y=3&submit.x=10〈=en&cc=us
SOURCE: I can't get my HP Laser jet 4350n printer to install
Did you try those drivers http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412160&prodNameId=412171&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ja-45284-10
SOURCE: printer offline
One possible reason could be that manually printer had gone offline.
You can go to Control panel - > printer & Faxes settings and right click your printer and click on user printer online. If you doen'nt find this option on right click means it is already in online mode, but somehow not able to communicate to the printer. Right click the printer and go to properties, click on port tab search for USB port and select USB.
Refer to the operating manual for printing test pages from printer.
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
Also refer to Dell forums on how to reset photo conductor
http://en.community.dell.com/support-forums/peripherals/f/3528/t/18405962.aspx
Hope this helps
Testimonial: "Thank you for helping me!"
