Televison & Video Logo
jason rabelo Posted on Mar 07, 2018
How do I connect my proscan tv remote to my fire stick
2answers
How can I delete my fire stick remote that is connected to my TV and how can I add it on
To disconnect your Fire Stick remote from your TV, you can follow these steps:
1. On the home screen of your Fire Stick, go to "Settings" in the top menu bar.
2. Navigate to "Controllers & Bluetooth Devices" and select "Amazon Fire TV Remotes."
3. Select the remote you want to disconnect and then choose "Remove."
4. Follow the on-screen prompts to complete the removal process.
To reconnect your Fire Stick remote to your TV, you can follow these steps:
1. Turn on your TV and make sure that it is set to the correct input for the Fire Stick.
2. Press and hold the home button on your Fire Stick remote for at least five seconds.
3. Wait for the remote to pair with your Fire Stick. Once the pairing is complete, you should see a message on the TV screen confirming the connection.
If you want to disconnect and reconnect your Fire Stick to your Element TV, you can follow these steps:
1. Unplug the Fire Stick from your TV's HDMI port and power source.
2. Wait for a few seconds and then plug the Fire Stick back into the HDMI port and power source.
3. Turn on your TV and switch to the correct input for the Fire Stick.
4. Follow the on-screen prompts to complete the setup process.
Once the setup is complete, you should be able to use your Fire Stick and remote as normal.
2answers
Samsung remote and Amazon Firestick
t's possible that the 5-year-old accidentally changed the input source on the Samsung TV, which is why you can't get the Fire Stick to work. Here are the steps you can follow to switch the input source back to the HDMI port where your Fire Stick is connected:
  1. Turn on your Samsung TV and your Amazon Fire Stick.
  2. Using your Samsung remote, press the "Input" button.
  3. A list of input sources should appear on your screen. Use the arrow keys on your remote to select the HDMI port where your Fire Stick is connected. The HDMI port may be labeled as "HDMI 1," "HDMI 2," or something similar.
  4. Press the "Enter" or "OK" button on your remote to select the HDMI input source.
  5. Your TV should now switch to the HDMI input where your Fire Stick is connected, and you should see the Fire Stick's home screen on your TV.
If you're still having trouble, try unplugging the Fire Stick and plugging it back in to make sure it's properly connected. Also, make sure the TV and Fire Stick are both updated to their latest software versions.
3answers
I'm trying to hook up my Amazon Fire Stick to my Proscan television and I don't have remote to either. How can I get the Fire Stick to work please?
Question edited for clarity and throw a few Capital letters in there.
You can't. You can only do simple functions from the device itself.
Buy the remotes for both.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
3answers
How can I fix the television remote control to access my Amazon Fire Stick please?
Pair Firestick remote to TV
Go to Settings on your Fire TV. Select Controllers & Bluetooth Devices. Select Amazon Fire TV Remotes. Press and hold the Home button for 10 seconds to pair your remote.
Amazon.ca Help: Pair Additional Fire TV Remotes
Videos as well
https://www.google.com/search?q=television+remote+control+to+access+my+Amazon+Fire+Stick
My dish remote will not turn on my proscan tv so a bought a rca universal remote and it turns the tv on but messed up everything else , so now I can’t get any channel s or pictures at all
Check the Source or Input button. You have accessed a source that has no input signal.
No one buys Universal remotes these days, you buy a facsimile remote that is an exact copy of the old one.
Proscan TV Remote Controls - Replacement Remotes
www.replacementremotes.com > Proscan > Remote-Con...
ReplacementRemotes.com offers Proscan remote controls for sale online including remote controls for TV, TV/DVD Combo, Sound Bar System and many more.
proscan tv remote - Amazon.com
www.amazon.com > proscan-tv-remote > k=proscan+tv...
Results 1 - 16 of 195 - GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, RCA, Panasonic, Smart TVs, Streaming Players, Blu-ray, ...
Proscan TV Replacement Remote
www.remotes.com > proscan-remote-controls-s
Replace new & discontinued remote controls for Proscan devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Proscan Remote Controls - Walmart.com
www.walmart.com > ... > TV & Video > TV Accessories
Products 1 - 40 of 43 - Shop for Proscan Remote Controls in TV Accessories at Walmart and
My fire stick remote won’t respond to Alexa commands from remote
hi Douglas298.
this is all i could find.
Fire TV Remote NOT Responding / Syncing / Connecting: SOLVED I've changed the Fire TV Voice Remote control batteries 5 times already but it still keeps disconnecting and now it's gone completely dead! Update 08/02/17: The most probable cause for your Fire TV remote not working is going to be the batteries. I know, you're thinking I've already changed the batteries twice already. The Fire TV remote is a fickle beast and only likes brand new fully charged batteries before it will re-connect to your Fire TV box. I've tried switching in batteries from other devices that are all working fine, but without any success. Brand new batteries are the key for this power hungry remote.
Has your Amazon Fire TV Box or Fire TV Stick become slow? See my Fire TV Slowdown Solution here.
This need for new batteries seems to be especially true when your Fire TV box is next to a complicated TV setup with AV, Speakers, WiFi Router all next to each other.
AMAZON FIRE TV 4K
AMAZON FIRE TV STICK
If you've tried brand new out of the packet batteries and it's still not working then you might have the same issue I had below. Don't forget to ask any questions you might have in the comments beneath this article.
Update: You can now control you Fire TV Device with the Amazon Echo & Amazon Echo Dot
If you've felt the annoyance of your Fire TV Voice Remote suddenly not connecting then I know how you feel. I've owned a Fire TV since October 2014 and up to now it's handled everything I've thrown at it. This is until one day last week when the remote suddenly kept disconnecting then died completely showing no signs of life.
I went through an array of different fixes to try and get it to work again but then finally I had a brainwave and managed to bring the remote back to life. It wasn't through trawling internet blogs and YouTube videos that I found this solution, it was actually from inspecting the remote more carefully. No, it wasn't Amazon's fault for building inferior products it was actually my own fault and partly the fault of cheap pound stores that litter the UK.
When I took the battery compartment off the Fire TV remote it looked completely normal. It wasn't until I raised the remote up to eye level that I noticed that there was a slight chalky residue on the connectors of the battery compartment. It then dawned on me as I looked across the room at a packet cheap pound shop batteries. One of the cheap batteries had leaked battery acid on to the Fire TV remote connectors blocking the current from getting through.
How to use your Fire TV when the remote won't turn on?
Luckily, Amazon have an App for that called Amazon Fire TV Remote that is available in the Android App Store and the Apple App Store. You can then control the Fire TV using the app and proceed to the next step below.
How to check if your Fire TV remote is connected to your Fire TV?
To see if your Fire TV remote is connecting to your Fire TV box or dongle you need to head to the settings menu.
  1. Settings > Controllers and Bluetooth Devices.
  2. Amazon Fire TV Remotes
This will show you what devices are currently paired and from here you can see if your remote is connecting. In my case when fiddling with the batteries my remote would appear here for a few minutes then disappear.
If all else fails, you can get an official Amazon FireTV Remote replacement.
The Solution
I took a flat head screwdriver and gently scraped the connectors of the Remote at each end. Wiping the residue off with a dry cloth as I scraped. The connector should look shiny and new again at the end of this process. I placed the batteries back in and the remote connected again straight away.
I've had no problems with the remote since and I guess the moral of the story is sometimes you get what you pay for... utter leaky batteries this time.
Fire TV Quick Tips
  1. Hold down the Select button for 5 seconds to put the remote into pair mode.
  2. Hold down the Select + Play buttons together for 5 seconds to Restart the device.
  3. Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in.
  4. or try this link.
fire stick remote wont respond to Alexa commands from remote Google Search
4answers
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
