20 Most Recent Proscan 19LA20Q LCD TV Questions & Answers
www.servicemanuals.com/
Try this link for a paid download.
Proscan 19LA20Q... | Answered on Jul 07, 2015
Google the remote's make and model with the word code added to the end. From there you will be directed to numerous sites with the info your looking for.
Proscan 19LA20Q... | Answered on Sep 04, 2011
Hello
Setup codes for proscan TV are:
0031 0107 0015 0000 0162 0163
Three digit codes are:
000/ 031/ 107/ 181
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Proscan 19LA20Q... | Answered on Jul 28, 2011
Hi, Is the power not turning on in your TV or do some of the buttons not work? It may well be that your power supply needs to be fixed. This may sound intimidating but, Don't Panic! Fixing that power supply of yours is not nearly as difficult as you might think.
How to Fix Bulging Capacitors in your Power Supply
Normal vs. Bulging CapacitorTaking Your TV Apart
Taking your TV apart might sound intimidating, but if it's broke already what can go wrong right? The truth is what you'll be doing has little chance of doing any real additional harm to your TV. If it does, or if taking your TV apart seems like too much work, then you can check out my article on new .
I can't have any clue of what your TV looks like. Some TVs are easier to take apart then others. As far as LCD TVs are concerned (flatscreens, LEDs, and Plasma included in this) there is probably a protective case over the back of your TV that can be easily removed. As you remove your protective case make sure to make note or take photos of where each screw goes so that you'll know for later.
Before we get started it's important for you to know what a capacitor is and what a bulging capacitor is. Capacitors is the most basic terms allow the power supply to keep a charge because of insulating materials they have inside of them. When a capacitor begins to bulge it needs to be replaced so that your power supply can continue to work.
Normal Vs. Bulging Capacitors (See image)
If the power to your TV has stopped working, then the most common problem is a bulging capacitor. Bulging capacitors look like the blue capacitor on the right. Sometimes you'll find more than one bulging capacitor in a power supply so make sure to look at all the capacitors in your power supply.
What kind of Capacitor do I need?
Every capacitor has a few important numbers on it. The most important is the number that comes before the µF (micro farad). Here's an example. Suppose you have a capacitor that says 1500 µF. Simply type in "1500 capacitor" in to e-bay and find one that looks like the one you have. *Make sure to check whether your capacitor is high heat capacity or not. These usually say something like "up to 105°C".
Replacing a Bulging Capacitor
A bulging capacitor like this simply needs to be unsoldered and replaced by a similar type of capacitor. If you don't have a soldering iron, then I've listed a few at the bottom of this article you can take a look at. After unsoldering the old capacitor replace it with a new one and finish it off by soldering it to the circuit board. After this simply put everything back the way it was. I hope you took good pictures!
Proscan 19LA20Q... | Answered on Apr 23, 2011
Hello
Just buy one Philips Universal Remote control [MODEL NUMBER CL 034]. Your proscan TV is listed in its codes. Codes are:
0704 0312 0103
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
flashes.
You will get its manual also with it, describes all the proceedings and codes for different set to which it can be used. OK.
Proscan 19LA20Q... | Answered on Apr 03, 2011
Probably the solder has let loose inside the television. Find someone handy, take off the back and solder it up. Use only Rosin Core Solder.....don't use Acid Core!
Make sure you don't short out anything!
Proscan 19LA20Q... | Answered on Mar 10, 2011
Have you tried the manual code search option that the Dish TV remote offers?
Proscan 19LA20Q... | Answered on Mar 04, 2011
Tries websites like Partstore.com,Ebay.com,Amazon.com should have the power a/c cord or cable,u looking for.
Proscan 19LA20Q... | Answered on Dec 31, 2010
Proscan 19LA20Q LCD TV Logo
54 questions posted
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
ned new remoute boght 4 non works
  • Televison & Video
