20 Most Recent
Amazon Fire TV Stick Questions & Answers
Why can't I register it?
https://www.
amazon.com/gp/.../ref=cs_hc_g_
tv?...
Amazon.com, Inc.Received my new fire tv stick today. I'm able to get past the wifi connection screen. But registering it with my Amazon account is I'm possible. Tried over 50 times ...
https://www.
amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.Make sure your Amazon Fire TV device is registered to your preferred Amazonaccount. To verify your registration ... Can't Access External Storage. Note: External storage options are not available for Fire TV Stick. First, make sure you're using ...
Wont accept registration details
https://www.amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.... five seconds. Or, open Settings > System > Restart from the main menu. ... Note: External storage options are not available for Fire TV Stick. First, make sure ...
www.
amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Dec 21, 2014 - No questions asked. .... I have the same problem because my network is considered open ... I'm trying to connect to a friends Xfinity wifi with fire tv stick, I have my laptop, Ipad & phone all working thru it but TV Stick won't. ... Mine wouldn'taccept password until I connect the HDMI extender - works fine now.
Fire TV Stick keeps asking for ...
Jan 3, 2015
KIndle Fire HD won't accept ...
Nov 2, 2014
How do I re-register my new ...
Mar 11, 2014
kindle won't connect with wi-fi
May 7, 2012
More results from www.amazon.com
Accidentally turned off my blue tooth on my fire stick now my remote will not work
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
My firestick remote wont work
1.Replace batteries.(in remote)
2.Get within 12 inches from firestick.
3.Press and hold home button for 10 seconds.
This should now pair with firestick, and should work.
Having trouble signing in on tv doesn't respond to my password
let's start with the basics first in order to solve your Amazon firestick issue. Once we go that, we can move forward as necessary.
The default tv password is 0000 (4 zeros). In ordet to set it back to this state, you can press the following keys in the given order: mute 8 2 4 [power-button] . Please double check that the tv is turned off before pressing those buttons from your remote control .
Please let me know if this helped you or not.
When changing programs it continues to move and does not stop until the end. Does not change one at a time.
It sounds like one of your channel-changing buttons is stuck in the "down" position. I would suggest removing the batteries from your firestick remote and then pressing the channel up/down buttons (used to change the channel) to "unstick" the button.
Network connection lost and can't navigate around screen
let's start with the basics first in order to solve your Amazon firestick issue. Once we go that, we can move forward as necessary.Amazon recommends that you restart your fire device by unplugging it's power for 1 minute and then powering the firestick device again. If this doesn't work, then you'll need to choose settings > network > then find your network name > then you can press play/pause to to check your network status.If you need any more help you can find the video in this link and/or start from step #5 as well: amazon.com/gp/help/customer/display.html?nodeId=GYMDPRQTTLXQD7PL&IWcIBc-1b4a9e Please let me know if this helped you or not.
How do I Jailbreak a Firestick? Is Jailbreaking a Firestick Legal?
Hi John!
To answer your question off the bat, jailbreaking a firestick is completely legal. You are actually not jailbreaking anything, but instead just loading third-party apps onto your firestick. Loading third-party apps onto your device is legal and is allowed by Amazon.
However, you could potentially get into trouble depending on what you are streaming with the third-party apps. If you are streaming something on the public domain then you are fine, however you may get into hot water with your ISP or government if you stream some things for free that are not on the public domain. It is important if you decide to jailbreak a firestick to always use a vpn so that your personal data on what you are streaming is protected and anonymous.
For a full tutorial on how to jailbreak a Firestick, I would check out Cord Cutters Anonymous. The website is great and will explain everything you need to know about jailbreaking a firestick and will show you the best apps available out there currently. Here is the full blog for how to jailbreak a firestick ->
http://cordcuttersanonymous.com/how-to-jailbreak-firestick/
And here is the Cord Cutters Anonymous home page where you can sign up for a newsletter to always be updated with the best firestick apps to load onto your device. ->
Hope this helps!
-mark
How do I register?
https://www.
Amazon.com, Inc.In order to use your Amazon Fire TV device, register it to your Amazon account. ...Differences between Amazon Fire TV and Fire TV Stick ยท Amazon Fire TV ...
https://www.
tv?...
Amazon.com, Inc.Received my new fire tv stick today. I'm able to ... But registering it with my Amazonaccount is I'm possible. Tried over 50 ..... How do I contact Customer Service?
I have accidently wiped KODI off my fire stick how do I get it back?
You can reinstall kodi on firestick with a lot of methods but one of them is given as follow
Similar to other methods, this method too requires you to enable installation from "Unknown sources." Once you do it, follow these steps.
Before these steps
STEP 1: Search FireDL on your Fire Stick.
STEP 2: Install FireDL and Open it.
STEP 3: Type 600003 at the top blank space.
STEP 4: The above code will automatically convert to the Kodi APK URL and download will start without any further actions from your side.
You can then install some great addons and builds to further enhance your experience.
19 Best Kodi Builds To Experience The Colors Of Kodi
