SOURCE: NO IP ADDRESS FOR THE AR-C270 sharp copier!!!!?
Custom settings, List print, Print test page, NIC Page.
SOURCE: Windows Vista Driver for TOSHIBA e-studio163 copier
check my link and go to copier manuals/ Toshiba drivers:
http://checkitright.spruz.net/main.asp?page=dp&dis=848698
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: I cannot delete a wrong email address from Windows
Click on the contact icon on the toolbar, The Doubl Click onthe contact to open the properties for the contact you want to change, click on the Name and E-mail tab, then select the e-mail address below, at the right, select Edit, and that will allow you to change the address to the correct one. and select ok. Your change shou;ld be accepted.
SOURCE: I cannot delete several of my messenger contacts
Seems Error Code 40402 pops up when trying to remove them while in your Yahoo Instant Messenger list first.
Glitches and Updates!!! Here's a work around though.
You will need to go to your Yahoo Email Account and delete the contact's name there first.
1. Click Contacts from your Email page to open your list of Contacts.
2. Go to the one you wish to remove and check the box next to it.
3. Go to the top of the list and click the Delete button.
Go to Yahoo Instant Messenger, right click the name and select Delete from the drop down menu.
