Click on the contact icon on the toolbar, The Doubl Click onthe contact to open the properties for the contact you want to change, click on the Name and E-mail tab, then select the e-mail address below, at the right, select Edit, and that will allow you to change the address to the correct one. and select ok. Your change shou;ld be accepted.
I'm confused, you said the e-mail address was incorrect and then correct. Either way you should be able to change it. I just tried it in Windows mail and had no problem. Try changing it from this way. When you get the New Message window up, next to the box where you type in the recipients name, select TO: In the contact listing, select the contacts name then select the name and e-mail tab. This si hte same window where you treid to change the e-mail address earlier. If yu select the e-mail address and select edit, you should be able to make any changes and have it show up in the Type resipients name box.
can you send a couple screen shots so I can see what your trying to do? Then maybe I can better help you fix the problem.
email me Ill reply if I can ever get into my own email its [email protected]
I attempted to send an email with wrong address which was not accepted. Now. every time I open my outlook express I'm requested to try to send that wrong email address again. How can I permanently get rid of that popup?
I tried the solution, but because the " contacts" address is correct I can't change the email address in " write email", where it says " type recipients name,etc," it still comes up wrong.
I believe I may have the same problem. The wrong address has been deleted from the contacts folder but when you create new mail and enter the first couple letters of the recipients address the old incorrect address is displayed automatically from the drop down menu as one of the choices. Does this better define the problem you have?
I accidently deleted the wrong account
