20 Most Recent Cavalry Storage Cavalry Retriever Series ENCAHDD2BU3CZB 25in and 35in Standalone SATA Duplicator and Hard Drive Questions & Answers
How do I delete my question?
As far as I know you can not delete your questions on this website.
6/11/2012 6:50:33 PM • Cavalry Storage... • Answered on Jun 11, 2012
Are you serious?
tell me your problem please
6/11/2012 5:03:58 PM • Cavalry Storage... • Answered on Jun 11, 2012
Cavalry hard drive gets error message
click start control panel administrative tools computer management then select event viewer depending on what operating sytem you have this may vary extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able work your way through the problem if it's a program file you might uninstall the program restart your computer then reinstall some of these files/software hope this helps
5/9/2012 9:43:17 PM • Cavalry Storage... • Answered on May 09, 2012
I have an unused internal 500 hard drive in an enclosure. Will upgrading it to a USB 3 enclosure do anything?
sadly we can not tell you if it will even work for what you want to do
11/27/2020 12:33:48 PM • Cavalry Storage... • Answered on Nov 27, 2020
Constant beeping from Cavalry external HD
Can't say exactly what it means technically speaking, but my experience with such a problem is that the drive is 'dead'. Of course trying it on another computer would be constructive.
12/15/2017 2:17:42 AM • Cavalry Storage... • Answered on Dec 15, 2017
My black calvary external hard drive won't turn on.
Would be great if the next time you also place the model number, because Cavalry makes dozens of different drives. When the bleu light does not go on, you have to assume the drive is not getting power. If the drive has only one cable, (small drives like 2,5 inch most of the time only have one cable) it could be the USB cable is defect and can't give through the 5 Volt coming from the computer USB connector. It also could be the 5 Volt supposed to be in the computer has gone. If you have to connect an external power supply, with a small cable to the drive, I would check the power supply. A 5 Volt 2 A supply, with the round plug can't be that expensive. If both don't work, it also could be inside the housing of the drive is something defect. If you need to have the data on the drive, you always could but an universal USB connection for hard drives. I have one for IDE and E-SATA, in the box came a set power cables and a power supply, but that one was almost 50 dollar. There are cheaper ones on the net. Be aware drives don't live forever and make sure you always have at least two backups. (that is more than one origin; and one back up)
6/17/2014 12:05:52 PM • Cavalry Storage... • Answered on Jun 17, 2014
Error message says I don't
Hi there, It sounds like your network administrator has locked your ability to write to certain folders. If this is a home hard drive, the only way to fix this would be to completely reinstall windows. If it's a work computer, you need to talk to your IT Department. -Alex
8/13/2011 2:15:34 AM • Cavalry Storage... • Answered on Aug 13, 2011
My computer not recognizing hard
check the power and data cables and try to but the bios into the default sittings
8/5/2011 1:30:26 PM • Cavalry Storage... • Answered on Aug 05, 2011
CAUO37500 Lite's on but nobody
im not sure how bad your hard drive is but if it works on another computer
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable, just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated hope this helps also you could run the chkdsk utility click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input may damage your computer then defragment your hard drive also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/
6/18/2011 8:10:59 PM • Cavalry Storage... • Answered on Jun 18, 2011
Transfer between 2 External Drives
the best program for this file transfer is Director Opus 9 this can transfer 100gig in under 1hr as with windows transfer takes 6hrs.
As I do alot of video capture and my filse range from 400mb to 4gig in size and having to transfer 700 gig about would take forever and with this program quick and easy you also can transfer over lan or wirless net.
happy transfering
7/9/2008 4:20:01 AM • Cavalry Storage... • Answered on Jul 09, 2008
Where can i get mastering machine learning Tips for Tackling Assignment
Here
The Ultimate Guide to Conquering Machine Learning ...
makexyz.com https://www.makexyz.com > the-ultimate-guide-to-conqu... Feb 19, 2024 - When diving into machine learning assignments, it's essential to adopt a systematic approach. Break down the task into manageable components, ...
7 Steps to Mastering Machine Learning with Python in 2022
KDnuggets https://www.kdnuggets.com > 2022/02 > 7-steps-masteri... Sep 30, 2022 - Step 1: Learn Programming for Machine Learning ... You need to have a working knowledge of programming before you dive into machine learning. Most ...
Machine Learning Assignment Help
Medium ยท Abnerassignmenthelp 1 month ago Our experts can assist you in tackling machine learning assignments effectively. Deep Learning Assignment Help: Our team of deep learning . ..
4/24/2024 8:11:03 PM • Computers &... • Answered 4 hours ago
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 20 hours ago
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered 2 days ago
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered 3 days ago
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered 3 days ago
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
Cavalry Storage Cavalry Retriever Series ENCAHDD2BU3CZB 25in and 35in Standalone SATA Duplicator and Hard Drive Logo
2 questions posted
Top Cavalry Storage Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Cavalry Cavalry Storage
  • Cavalry Cavalry Storage
Most Popular Question
delete question
  • Computers & Internet
