Re: My Royal paper shredder model VF1700mx has stripped...
You will have to contact the ,manufacturers spares or service agent for the brand but generally if a gear has stripped, it is cheaper to junk it and replace it with a new unit
Thanks for the advice bill. I checked with the manufacturer and they said the part was no longer available. guess I'll go shopping. R. KnightThanks for the advice bill. I checked with the manufacturer and they said the part was no longer available. guess I'll go shopping.
R. Knight
You can't post conmments that contain an email address.
Take a look inside at the cutting blades when it is running...do the cutting shafts turn??? it sounds like they ARE NOT. If they are not turning but you can hear the motor running then you probably have a broken gear, or striped teeth on a gear. You will have to open it up to see which gears are the problem...then you can contact Royal at 1-800-524-0799 for parts assistance.
If the moter runs but the cutting shafts are not turning then you have likely stripped a gear.... unplug, open top to see which one the give Royal a call at 1-800-524-0799; they should be able to help with parts.
If you can hear th motor turning but nothing else is turning...you have probably stripped teeth off a gear inside.
Unplug machine, take cover off and determine which gear/gears.....
you can call Royal at 1-800-524-0799. for parts.
