20 Most Recent Royal MS 25 Typewriter Questions & Answers
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
4/17/2016 4:21:13 PM • Royal MS 25... • Answered on Apr 17, 2016
A string broke, space bar and platen does not
The tab cord is probably what broke. If it a string some 50# fish line will probably work.
DickyO
5/17/2011 6:07:03 PM • Royal MS 25... • Answered on May 17, 2011
L.C. Smith & Bros. typewriter No. 5 Margin setting
Make sure the carriage lock switch isn't on (presuming it has one). A carriage lock switch prevents the carriage moving when in transit (say, inside its case). These switches are usually located on the right hand side of the carriage, slightly underneath.
Gordon
1/12/2011 10:22:21 AM • Royal MS 25... • Answered on Jan 12, 2011
I have a circa 1940's-50's Royal Desktop
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
10/18/2010 5:21:01 PM • Royal MS 25... • Answered on Oct 18, 2010
I can only type a few inches into a sentence
At the top of the typewriter behind the platen (the big black rubber roller you roll the paper into) there is a scale with two push buttons on it. The buttons are the margins. The button on the right is the one stopping you. Push it down and slide it to the right to set your new stopping place...or all the way to the right to not have any margin at all.
4/26/2010 1:31:24 AM • Royal MS 25... • Answered on Apr 26, 2010
Return arm on smith-corona silent typewriter does not advance
The linespace selector lever is probably at zero 0
try moving it to 1 1 1/2 or 2. There is also a detent lever that releases the ratchet of the roller. You should feel a bumping when you move the roller wheel.
12/19/2009 2:38:13 AM • Royal MS 25... • Answered on Dec 19, 2009
Royal Orca 9512X Business Shredder printed circuit board part?
This is the only place that says it might? https://www.pacparts.com/library/model.cfm?mfg=Royal&model_id=ORCA%209512X&action=list_part&back=0 ShredderParts.com is the go-to place, but they don't keep parts. https://www.google.com/search?q=Royal+orca+9512x+parts Your best bet is probably going to be to take the circuit board to an electronics technician and ask them to test and replace components that have failed. ..
2/21/2022 10:21:24 AM • Royal Office... • Answered on Feb 21, 2022
2answers
What's a PCB on a Royal 1212X shredder? And how do I know the PCB is the problem?
A pcb is a printed circuit board. You can visually check it for very small burn spots or tiny melted disconnections, or swollen or burst capacitors; but any repairs of the PCB are risky because of the interdependencies of any circuitry. If you've already checked the mechanical workings, you might try to find a replacement PCB if you're convinced that's the problem. They're often not even sold, so a whole new unit would be required. Welcome to the wonderful world of planned obsolescence.
2/8/2022 3:18:52 AM • Royal Office... • Answered on Feb 08, 2022
My Royal Alpha 9170 is feeding to quickly, resulting in a paper and ribbon jam and resulting in a printer error.
hi
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved
12/9/2021 3:51:57 PM • Royal Office... • Answered on Dec 09, 2021
Royal 1610X wheels
Casters enable it mobility from office to office. Royal 1610X is a cross cut paper shredder designed for heavy duty commercial and office usage. This Royal office paper shredder will shred up to 12 sheets of paper at once. Royal 1610x also provides continuous shredding of 10 sheets of 16 inch wide computer form paper.
1/14/2021 3:02:24 PM • Royal Office... • Answered on Jan 14, 2021
User's manual Royal Organizer DS2080
Photo shows quick reference guide with a few steps. Possibly one of the sellers can respond to a question on Amazon concerning it, or possibly provide or sell a copy of the instructions. https://www.amazon.com/Royal-Electronics-Organizer-Calculator-Compatible/dp/B006QV87KW
6/26/2020 5:27:12 PM • Royal Office... • Answered on Jun 26, 2020
I need micro power switch for royal 1212x.
order one fixya does not sell products
4/14/2020 2:31:51 AM • Royal Office... • Answered on Apr 14, 2020
I have a Royal scripto 11 and keys won'y print or hit the paper
https://www.youtube.com/watch?v=oyRXJNYOegs https://www.youtube.com/watch?v=URhjSGGaq6c
3/14/2020 5:26:08 PM • Royal Office... • Answered on Mar 14, 2020
How to clean blades on royal shredder
Soapy Water
1/23/2020 12:44:57 PM • Royal Office... • Answered on Jan 23, 2020
Royal MS 25 Typewriter Logo
Popular Tags
11 questions posted
Top Royal Office Equipment & Supplies Experts
David Shaub
Muzahura Frank
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Royal Office Equipment & Supplies
Most Popular Question
circa 1940s 50s royal desktop
  • Office Equipment & Supplies
