The dryer has showing the error E-05. I Just want to know how to fix the problem.Please help me to fix the error.
Sounds like your breather is blocked look at the bottom of the unit for a filters remove and clean
Big
Posted on Sep 28, 2016
SOURCE: KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This model is manufactured by Whirlpool, so maybe you can locate your model's failure codes.
http://www.repairclinic.com/0078.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 22, 2008
SOURCE: My Samsung electric dryer, model DV337AEG is
You have a bad heating element. I just went through the same problem with mine
Posted on Jul 26, 2009
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 25, 2009
SOURCE: Electrolux dryer stuck in demo mode
To deactivate the demo mode:
Turn cycle knob to last cycle on right. Press start to save cycle position.
Press cancel to turn machine off.
Within 10 seconds, wake unit by pressing start once, immediately press and hold cancel and right most key under the display together for a minimum 6 seconds.
“DEMO MODE” will no longer be shown in the display.
Posted on Nov 18, 2009
SOURCE: Kenmore Elite Oasis Electric Dryer, Model #110.6708*, 6709*
Hi, my Kenmore Oasis Elite electric dryer has a poor fitting lint screen which allows for a large build up of lint in the bottom of the motor housing. This lint has also become blackened as if exposed to high heat. Some electric wires also show evidence of the plastic coating turning black and over heating. I get the feeling this unit is a fire hazzard. Model # C6704 A few days ago there was a distinct odour of electrical burning. This unit was purchased new in Dec. 08. Anyone else have this experience?
Posted on Apr 27, 2010
I appreciate your inquiry, Ape!
From what you have described your Electrolux dryer is displaying an error code of "E75". An"E75" error code is not showing as a valid error code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your dryer. You can do that by disconnecting the power from it for ten minutes. Could you please provide me with your model number? You can normally locate the model number on the serial tag which is located on the door frame. Also, once you reset it can you provide feedback if you continue to receive that error code. Good luck. -Matt
Hi - Typically error code E08 on Electrolux models indicates that it is recommended for a professional to check the mist value on the motor. Try resetting the unit by unplugging it or flipping the breaker to the household circuit breaker. Wait approximately ten minutes and turn on the dryer. If the error code does not clear and it is ineffective, contact a professional to move forward accurately.
