20 Most Recent Electrolux EIED55H Dryer Questions & Answers
manual
We just recently moved, and
-Try difference outlet. If it works then the first outlet you plug in has no power. -You said you already check the breaker. it looks fine. -Did you do any thing to the breaker or just look...? -If the outlet that you want to use still has no power then how about try this: -Open the breaker panel. Flip all breaker off, then flip all on one by one and check again. If you have power now then good. But still have no power then most likely the previous owner or renter disconnect the wires to that outlet from its connector. At the junction box or may be at the breaker. Good luck Mai
1/19/2018 4:52:30 PM • Electrolux... • Answered on Jan 19, 2018
Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control. If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
11/9/2016 7:48:46 PM • Electrolux... • Answered on Nov 09, 2016
DRYER NOT DRYING CLOTHES ALL THE WAY FILTER IS CLEAN AND CLEANED OUT THE LINT TRAP AND COVER. NO CODE GIVEN. HAVE TO RUN TWO CYCLES.
Clean the exhaust duct. The ENTIRE duct, from where it attaches to the dryer to where it exits the house... Failure to dry clothing when you have heat is an air-flow issue
6/14/2016 2:33:01 PM • Electrolux... • Answered on Jun 14, 2016
Hi, I have a double oven electrolux icon model number e30ew8cgps6. I would like to tighten the handle but only see one screw on the right side and the are three plastic covers remaining and its but
From what I can see in the parts diagram, it looks like you need to pop off a plastic cap and then tighten the screw to the handle: http://c.searspartsdirect.com/lis_png/PLDM/R1105038-00003.png Good luck!
10/20/2014 12:43:15 AM • Electrolux... • Answered on Oct 20, 2014
0answers
How to take front panel off an Electrolux EIED55HIWO dryer?
Good Afternoon Friend, I understand you want to know how to remove the front panel of your Electrolux dryer, model# EIED55HIW0. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to remove the front panel with ease. Hope this is helpful. -Best Regards- WP
7/3/2014 5:16:04 PM • Electrolux... • Answered on Jul 03, 2014
How to clear code on electrolux dryer
Good Afternoon Friend, I understand you are trying to clear a code on your Electrolux dryer. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
6/27/2014 5:27:52 PM • Electrolux... • Answered on Jun 27, 2014
My front load dryer is displaying all 8's and all lights are blinking what does this mean
Good Morning Friend, I understand your Electrolux dryer, model# EIED55H, is displaying all 8's and all the lights are blinking. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best regards- WP
6/27/2014 3:35:55 PM • Electrolux... • Answered on Jun 27, 2014
Electrolux dryer error code e62
Good Afternoon Friend, I understand you are receiving an E62 error code on your Electrolux dryer, model# EIED55H. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful. -Best Regards- WP
6/12/2014 9:37:35 PM • Electrolux... • Answered on Jun 12, 2014
2answers
ERROR CODE E64 FOR FRIGIDAIRE AFFINITY
Please CALL Frigidare. We have had the same problem with our dryer and now the washer quit! Our set is only 3 years old! With all of the problems reported on the Internet there should be a recall on this set! They need to be informed! I am highly disappointed in the short lifespan of the Affinity Washer and Dryer. Dont know if I would purchase this brand ever again!
5/1/2014 6:22:43 PM • Electrolux... • Answered on May 01, 2014
Dryer lights are flashing from one side to the other, no code is flashing, the time screen shows 88:88 with a bar below it
sounds like a faulty circuitry board has malfuctioned. sorry it might be dead.
3/12/2014 1:36:47 AM • Electrolux... • Answered on Mar 12, 2014
Electrolux Dryer quit and has a code E 63
Mark, the heating element is underneath the drum, on the left (as facing the front of the unit). Per the Dryer Tech Data Sheet: E63 Error Code indicates: [Fault] Heater to Earth Ground [Possible Fault Conditions] Heating element or wiring defective [Possible Solutions] Check heater coils and connections for short circuits to the cabinet. Replace heater and/or wiring and retest. To open the cabinet is quite difficult, speaking as a non-professional. There may be easier methods than what I used, but I was successful. First I removed all the screws from the back (there are many). This got the top and the back panels removed. The left side (where I could see the heating element was) gave me considerable trouble until I realized I had to remove the door trim to reveal one last screw. Finally got the side off and swapped out the heater. Much much vacuuming for me. I am still trying to figure out how to clean out the bottom of the duct (underneath lint filter), but that's another post. Also, just in case you don't have the manual and/or need to order parts, I will include a link. http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Dryer-Parts/model-EIED55HIW0/1412/0151200 For some reason, the Sears Parts Direct website lists the dryer as a Gas dryer, which it obviously isn't, as the part in question is very clearly an electric heating element. Hope this helps. -Nick
3/4/2014 6:58:44 AM • Electrolux... • Answered on Mar 04, 2014
3answers
Dryer shows E63 error code?
The error code E63 is a high temperature warning
If you dryer is under warranty, take advantage of it. If not it may be a failing sensor or possibly a control board.
2/19/2014 5:47:45 PM • Electrolux... • Answered on Feb 19, 2014
Electrolux EIED55H Dryer Logo
137 questions posted
Top Electrolux Dryers Experts
vince
NOEL
NOEL
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Dryers
  • Electrolux Dryers
Most Popular Question
electrolux dryer quit code e 63
  • Dryers
