20 Most Recent Electrolux EIMED55IMB Laundry : Dryers Questions & Answers
My Electrolux dryer is throwing the code ehi
That is not a standard code. You won't find it on the Electrolux site. I can infer nothing from that. You can either try the general troubleshooting tips for Electrolux dryers OR try to contact Electrolux customer support. Since I have no access to whatever this code means, I can't assess the problem. Here is a troubleshooting video for Electrolux dryers: https://www.youtube.com/watch?v=5dDqrB3nk2s
10/22/2023 2:49:20 AM • Electrolux... • Answered on Oct 22, 2023
2answers
Error code e64 dryer Electrolux FFSE5115PW2
How to Fix Electrolux Dryer Error Code E64
Appliance Express https://applianceexpresstx.com > News and Tips Apr 10, 2023 - If your Electrolux dryer is showing an E64 error code, this means there is a problem with the heating circuit. When this occurs, your dryer ...
Common Electrolux Dryer Error Codes & How to Fix Them
Just-in Time Appliance Repair https://justintimeappliance.com > blog > common-elect... Feb 3, 2020 - Another of the more common Electrolux dryer error codes, E64 indicates a malfunction with the heater's wiring or the heating element itself.
How To Fix Frigidaire & Electrolux Dryer Error Code E63 E64
howtofixit.net https://howtofixit.net > how-to-fix-frigidaire-electrolu... Oct 18, 2020 - These E63 or E64 error codes generally mean that you have an issue with the heating element ... Videos for E64 Error.
6/12/2023 6:24:48 PM • Electrolux... • Answered on Jun 12, 2023
2answers
Electrolux Dryer screen went blank
I am not sure what your Dryer model is or its age but it could well be that there is a plug loose on the main control board or some fault on the wiring inside the top behind the display panel.You could check to see if this is the case but make sure the mains power is off first,remove the top lid and check,or It would be best to get in touch with Electrolux to see if a repair is covered under the Warranty.
Hope this helps.
Good luck.
12/4/2022 5:08:57 PM • Electrolux... • Answered on Dec 04, 2022
What does e62 mean on an Electrolux clothes dryer
This error code indicates the water is overheating during the wash cycle. The first thing to check is if the water inlet hose is connected to the cold outlet and not the hot one. If the hose is properly connected, the temperature sensor will need to be checked and if faulty, replaced.
11/5/2022 5:52:24 PM • Electrolux... • Answered on Nov 05, 2022
Heating element needs to be changed for my electrolux model EIMED55IIWO dryer. The front panel will NOT come off. Help please!
Go to repairclinic.com and watch a pro disassemble a typical Electrolux dryer.
3/29/2022 10:25:56 PM • Electrolux... • Answered on Mar 29, 2022
Where is the reset button on an Electrolux dryer?
Difficult without a Model. Electrolux make about a thousand dryers! To reset your Electrolux dryer, press and hold the "temperature" and "dryness" buttons simultaneously. Keep these buttons depressed for at least six seconds to reset the machine. If this doesn't clear your error code, you likely need service.
Key Stuck Message on an Electrolux Dryer ' Hunker
Videos as well https://www.google.com/search?q=electrolux+dryer+reset+button ..
1/11/2022 11:50:07 PM • Electrolux... • Answered on Jan 11, 2022
Message says door open when door is closed for an Electrolux Dryer 2012 purchased
DEFECTIVE DOOR SWITCH
10/3/2021 8:20:18 PM • Electrolux... • Answered on Oct 03, 2021
2answers
No power to my electrolux edv605 clothes dryer. no lights no nothing, what could be wrong?
Plug it in after checking the main fuse.
4/23/2021 5:02:19 AM • Electrolux... • Answered on Apr 23, 2021
Model EIMGD55IIW2. How can I check voltage between board and gas valve?
check gas pressure if ok bad gas valve
1/26/2021 3:08:59 AM • Electrolux... • Answered on Jan 26, 2021
Model EFME627UTT. It starts, but why does it turn off within a minute?
either transformer overheating and turning off or motor
1/24/2021 7:30:33 AM • Electrolux... • Answered on Jan 24, 2021
My electrolux dryer a couple months back gave me error code 64. I researched and replaced the heater coil along with the two parts attached to it. The limiter and thermostat if I remember correctly. That part failed and I got error code 65 after only two weeks. When I removed the coil it had obviously gotten to hot and the coils warped and touched the side walls. I Replaced again and now I’m getting the same code. What could be causing it to fail over and over?
I don't know if modern dryers use electronics to regulate the element temperature and protect against overheating but if yours is like that it is clear they aren't doing the job. Older dryers don't have temperature regulation and mostly don't need it - the only reason they overheated was if airflow was restricted and then the thermal cutout would trip, resetting itself as it cooled. Usually the system is bulletproof because of safety concerns. I am wondering if the element you are fitting might be for the wrong voltage or if it is a dual element whether it is being connected correctly...
4/29/2020 2:32:31 AM • Electrolux... • Answered on Apr 29, 2020
2answers
I have an Electrolux mod ede37100w dryer it takes three or four cycles to dry the cloths what could be the problem? I have the machine in pieces right now is there more than one thermal fuse in it?
I suspect either the lint trap is completely stopped up or the dryer hose is clogged up. From the limited information I have to go on I doubt it is a thermal fuse.
9/10/2019 8:18:44 AM • Electrolux... • Answered on Sep 10, 2019
Electrolux t3350 error15
I have an electrolux electical dryer t3350 gave the error E 08
8/22/2019 5:42:42 AM • Electrolux... • Answered on Aug 22, 2019
2answers
My Electrolux drier mod#eimed5511wo is showing an error code of E64 cuts off about 5 minutes after it is started
Contact the manufacturer and find out what the error code is for.
7/15/2019 7:42:32 PM • Electrolux... • Answered on Jul 15, 2019
HOW TO UNLOCK CHILD LOCK OF ELECTROLUX DRYER MOEL EDP207 4PDW
Press and hold touchpads "time" and "wool load" at the same time until the child lock indicator turns off.
7/14/2019 1:16:27 AM • Electrolux... • Answered on Jul 14, 2019
Electrolux EIMED55IMB Laundry : Dryers Logo
0 questions posted
Top Electrolux Dryers Experts
vince
NOEL
NOEL
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Dryers
  • Electrolux Dryers
Most Popular Question
message says door open when door closed
  • Dryers
