20 Most Recent Electrolux Kenmore 5.8 cu. ft. Super Capacity Electric Dryer Questions & Answers
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
7/12/2014 3:46:21 PM • Electrolux... • Answered on Jul 12, 2014
I need a tensor pulley
http://www.repairclinic.com/Kenmore-Dryer-Pulley-Parts?z=100
11/25/2010 9:51:09 PM • Electrolux... • Answered on Nov 25, 2010
Our dryer makes a loud clunky sound, must be out
maybe drum glides/rollers,belt,motor or idler pulley:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
10/30/2010 2:46:37 AM • Electrolux... • Answered on Oct 30, 2010
0answers
2answers
Electrolux Dryer screen went blank
I am not sure what your Dryer model is or its age but it could well be that there is a plug loose on the main control board or some fault on the wiring inside the top behind the display panel.You could check to see if this is the case but make sure the mains power is off first,remove the top lid and check,or It would be best to get in touch with Electrolux to see if a repair is covered under the Warranty.
Hope this helps.
Good luck.
12/4/2022 5:08:57 PM • Electrolux... • Answered on Dec 04, 2022
What does e62 mean on an Electrolux clothes dryer
This error code indicates the water is overheating during the wash cycle. The first thing to check is if the water inlet hose is connected to the cold outlet and not the hot one. If the hose is properly connected, the temperature sensor will need to be checked and if faulty, replaced.
11/5/2022 5:52:24 PM • Electrolux... • Answered on Nov 05, 2022
Heating element needs to be changed for my electrolux model EIMED55IIWO dryer. The front panel will NOT come off. Help please!
Go to repairclinic.com and watch a pro disassemble a typical Electrolux dryer.
3/29/2022 10:25:56 PM • Electrolux... • Answered on Mar 29, 2022
Where is the reset button on an Electrolux dryer?
Difficult without a Model. Electrolux make about a thousand dryers! To reset your Electrolux dryer, press and hold the "temperature" and "dryness" buttons simultaneously. Keep these buttons depressed for at least six seconds to reset the machine. If this doesn't clear your error code, you likely need service.
Key Stuck Message on an Electrolux Dryer ' Hunker
Videos as well https://www.google.com/search?q=electrolux+dryer+reset+button ..
1/11/2022 11:50:07 PM • Electrolux... • Answered on Jan 11, 2022
Message says door open when door is closed for an Electrolux Dryer 2012 purchased
DEFECTIVE DOOR SWITCH
10/3/2021 8:20:18 PM • Electrolux... • Answered on Oct 03, 2021
2answers
No power to my electrolux edv605 clothes dryer. no lights no nothing, what could be wrong?
Plug it in after checking the main fuse.
4/23/2021 5:02:19 AM • Electrolux... • Answered on Apr 23, 2021
Model EIMGD55IIW2. How can I check voltage between board and gas valve?
check gas pressure if ok bad gas valve
1/26/2021 3:08:59 AM • Electrolux... • Answered on Jan 26, 2021
Model EFME627UTT. It starts, but why does it turn off within a minute?
either transformer overheating and turning off or motor
1/24/2021 7:30:33 AM • Electrolux... • Answered on Jan 24, 2021
My electrolux dryer a couple months back gave me error code 64. I researched and replaced the heater coil along with the two parts attached to it. The limiter and thermostat if I remember correctly. That part failed and I got error code 65 after only two weeks. When I removed the coil it had obviously gotten to hot and the coils warped and touched the side walls. I Replaced again and now I’m getting the same code. What could be causing it to fail over and over?
I don't know if modern dryers use electronics to regulate the element temperature and protect against overheating but if yours is like that it is clear they aren't doing the job. Older dryers don't have temperature regulation and mostly don't need it - the only reason they overheated was if airflow was restricted and then the thermal cutout would trip, resetting itself as it cooled. Usually the system is bulletproof because of safety concerns. I am wondering if the element you are fitting might be for the wrong voltage or if it is a dual element whether it is being connected correctly...
4/29/2020 2:32:31 AM • Electrolux... • Answered on Apr 29, 2020
Electrolux Kenmore 5.8 cu. ft. Super Capacity Electric Dryer Logo
9 questions posted
Top Electrolux Dryers Experts
vince
NOEL
NOEL
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Dryers
  • Electrolux Dryers
Most Popular Question
clothes get stuck between dryer barrel
  • Dryers
