Question about Vulcan Heating & Cooling
Hi. Have just replaced the pressure switch on our Vulcan 9151 and still have the same problem of not firing up. Connections are all good tight and not blocked. If I remove a hose from the pressure switch and then replace it back on the PS it fires up. But I have to keep doing this every time I want the heating on ??
SOURCE: Rear cylinder not firing
95 Evo, new plugs, new wires, started backfireing like a machine gun, front cyl. no spark at plug sometimes - would this be the coil, have not ohmed the coil yet . Thanks
Posted on May 13, 2009
SOURCE: Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Posted on Jun 23, 2009
SOURCE: lack of power, hesitation, #1 miss firing
you may need to perform a leak down test to the cyliner and maybe you may have carbon on that valve. make sure the new spark plug wire has the correct continiuty
Posted on Jul 27, 2009
SOURCE: Honda s2000, 2001 loose of
Sounds like an ignition component failure check for proper resistance through primary and secondary ignition coil windings, refer to service repair manual for exact specs, also the ignitor magnetic pick up may be not up to snuff, the only other ignition component to replace or check is the ignition module and/or plug wires themselves, sometimes when extreme demand is put on the ignition system the plug wires must be high quality and completely isolated from one another. Spark plug wires when routing cannot come in contact with one another in the slightest proximity.
Posted on Aug 23, 2009
SOURCE: 99 vw passat sw 1.8t #3 cyl not firing.
ihad the same problem.. its not the coils or anything like that.. and any reg mechanic wont know the prob unless they under vw.. u need to replace ur power output stage.. thats what cylinder 3 misfire is.. after i fixed it my car is good as new. i
Posted on Oct 14, 2009
My 2006 vulcan 900 won't start after I replaced starter and battery. It makes a tickering sound when I try to turn it on.
Jul 28, 2012 | 2006 kawasaki Vulcan 900 Classic
Jul 13, 2012 | Televison & Video
Mar 25, 2017 | HP La2405wg 24 inch LCD Monitor
Jun 20, 2011 | Office Equipment & Supplies
May 13, 2011 | 2000 kawasaki VN 1500 Vulcan Classic...
Mar 21, 2010 | 1990 Ford F150
Sep 15, 2009 | 1996 kawasaki VN 800 Vulcan Classic
Dec 07, 2008 | Vulcan EF3 Deep Fryer
Nov 05, 2008 | Microsoft Office Professional 2007 Full...
