Question about Vulcan AUW230A Heater
We have a Vulcan Ultra high efficiency gas ducted heating
We have a Vulcan Ultra high efficiency gas ducted central heater. It doesnt want to switch on all of sudden. no problems appear with the controller. Any ideas? The unit is under the house, not sure whether the pilot light is off or whether the unit actually has a pilot light. Product number 5000023
Posted by yvette_miode on
Anonymous
    New Friend:
Gas ducted central heater won't switch on all of a sudden
Posted on Sep 21, 2010
Paul Carew
  • Vulcan Master
  • 3,534 Answers
Hi could be the pressure switch or the hot surface igntor not working go and see when you turn it on does the ignitor glow red
Posted on Feb 18, 2010
brendon26200
Check the fault code to see what is the problem
Posted on Oct 02, 2011
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
I have a Vulcan Ultra 21E ceiling ducted unit The LED flashing fault is no 8 which is a gas interruption. The unit fan runs, ignition starts full flame and gas flows for about 2 secs then shuts down The...
Just been thru a similar problem with my Climate Technologies Vulcan High Efficiency Ducted Gas heater which in this case is installed under the house. This heater is about 7 years old and I have previously (2 years back) refurbished the controller by replacing the main power supply electrolytic filter capacitors.
I also had a communication problem with the Touch pad Thermostat which in the end required replacing the entire touch pad as one of it's voltage regulators had gone intermittent (Touch pads are available on E-Bay). To operate the heater while the touch pad was out of commission I installed a manual switch between the heat contacts on the heater controller. Closing the switch causes the heater to permanently run if it has no thermostat. Once communication with the touch panel was restored we were able to try and find the intermittent heater fault.
Again I have been getting Fault Code 08 "Gas Interruption" however the heater was lighting OK and then going out after about a minute or so. In the end I found 2 distinct heater faults.
Fault 1 was the flame sensor where the weld between the wire and flame probe rod had broken but it was still touching. This meant it was sensing Flame OK and then later would go open with expansion as the temperature rose. I fixed this by replacing the Flame Probe with a new one sourced from Reece HVAC.
At this point I celebrated thinking it was fixed!
Fault 2 after the flame sensor issue was cleared the fault still persisted but slightly less often.
The heater was cycling 3 times to get going and then locking out, requiring a reset from the touch thermostat or heater controller board. Sometimes the heater would achieve a onging burn for a long period, and other times just locking out after 3 tries.
Careful observation of the flame, through the observation holes after it lit, showed correct flame sensing but as soon as the nominal 65C duct temperature was reached the combustion fan (modulates) throttles back too far and the flame goes out, the flame sensor switches off and gas valve is then closed. The pressure differential across the burner manafold controls the Gas flow rate so if the combustion fan goes too slow the flame goes out due to lack of gas.
On the control board there is a potentiometer marked "MIN GAS RATE" this needs to be tweaked clockwise until the burner remains lit when the nominal 60-65C duct temperature is reached. Don't turn it up too far or the heater may not throttle back enough and end up going out on overheat.
Once a stable flame is achieved when throttled, try the heater in the economy mode which uses a lower recirculating fan speed and check the flame still remains lit. My problem was most obvious in the Econ mode.
Hope this helps someone else - It took me over a year to solve this one. NeilP
Aug 21, 2011 | Heating & Cooling
Pilot lights but won't stay on in my older style vulcan space heater. thermo couple was replaced last year.any ideas that i could try thanks
Most common cause of pilot light problems is air movement. If your space heater exhausts gas through the roof, ensure the cap is on and level. If not, outside air movement will blow out the pilot. If you do not have an exhaust gas duct, check that the unit is positioned so that it does not blow air back onto itself from walls, furniture, etc, and ensure no other devices that move air are aimed towards the unit. The unit also needs to be placed away from central ducting, including return vents.
Hope this helps!
Aug 09, 2010 | Vulcan AUW230A Heater
Takagi Jr Flash Water Heater Problem
explain your problem.
Takagi is a great tankless heater, very few problems...
need more info
Aug 04, 2010 | Ultra Max Takagi Flash TH-1 Ultra High...
Is vulcan duct heater still in existence? My problem is the thermostat control for the room temp has gone out of control - from 22 -35 0C. This has affected the heater cut off efficiency.
Yes. Vulcan heater company is still making heaters. Here is the link. http://www.vulcanelectric.com/
Grainger is a direct seller of Vulcan heaters, so you chould be able to give them a call, explain what you need or giver them a part number and they will be able to get what you need.
May 12, 2010 | Vulcan AUW230A Heater
Vulcan AUW230A Heater Logo
3,701 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
