2000 kawasaki VN 1500 Vulcan Classic Tourer Fi Logo
Posted on May 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coolant fan continues to run after shut down and drains the battery
Anonymous
Level 3:
Genius:
  • Master 1,140 Answers
  • Posted on May 13, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1140
Questions
0
Helped
335865
Points
3007
Plop down around 80 bucks for a new fan control switch. just replaced mine for the same damn problem, easy to replace though.
96 1500 Vulcan Classic
I have a 2012 Kia Sorento and the cooling fan will not shut down. Ishut the engine off and it has been running for 30 minutes. Now it has run down the battery down
There is a thermostat which turns the fan on and off to maintain a reasonably level temperature of the coolant. If the fan has stayed on, I would think that the thermostat has jammed on and that's why it keeps the fan running. You will need a new thermostat. ( Not the water thermostat that is in the engine) A fan thermostat is what you will likely need.. A Dealer or parts outlet shop will know what you need.
What causes fan to continue running when engine is off and the battery is drained
it could be a faulty fan relay, however some of these had a continue run time program that allowed the motor to cool off after engine shut down. it shouldn`t run longer than about 2/3 minutes.
2001 chevy prizm fan runs after engine is shut off until the battery is completely drained
Replace the relay its stuck on,water out the exhaust could be condensation.
Cooling fan continues to run after engine shut off.
The fan runs for a short time, after ignition off, to continue to cool the hot engine.
3answers
When i turn off the car the fan continues to run?
Many cars have this feature. The fan will run for a few minutes at a time until the coolant in the radiator drops below a certain temperature. Most vehicles with this feature will have a warning label on the radiator shroud indicating that the fan may start without warning when the engine or radiator is still hot. The only time you would need to be concerned would be if the fan continues to run without turning itself off, and causing the battery to be drained.
3helpful
Engine fan runs after car shut down
The most likely cause of this problem is a part called a "Fan switch".
http://www.tegger.com/hondafaq/misc/view_from_bottom.jpg
This link should be the location where yours is located. When it is working properly, it turns on the fans when the coolant reaches a certain tempeture.. In your case im assuming the switch is defective.. and stuck open.
1helpful
97BMW 318i fan runs and drains battery when car is off
Yes pull the cooling fan relay in the fuse panel. It might be bad.
1999 grand cherokee jeep -coolant fan will not shut off
Hi Jeepers,
The fan will occassionally continue to run for five or ten minutes after the vehicle shuts down. This is normal.
What is not normal is if it keeps running until the battery drains.
Does it just keep running?
If it eventually shuts off, how long does it take?
Did this just start happening?
The two days you mentioned, were they short trips, opposed to the third day?
If you would comment me back with some more details, it would help me help you.
Mike
2answers
Electric fans runs after car is shut off, drains battery
Having the fan run on for a bit after the engine has stopped is not abnormal in itself, but 20 minutes sounds excessive.
If the fan does eventually shut off, I'd consider changing the thermoswitch (this is a sensor screwed into the radiator somewhere near the bottom, with a pair of wires connected to it - to change it, you'll need to drain the cooling system).
If the fan stays on continuously until the battery is completely flat, see what happens when you unplug the wires from the thermoswitch. If this stops the fan, you need to replace the thermoswitch. If it doesn't, then you need to examine the wiring associated with the switch and the fan, looking for damaged insulation.
A.
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
