GE( 2-door) ref portion door left open the whole night,it's not working now except the freezer. Tried unplugging it for 24 hrs, but still not working.
the air ducts could still have ice in them,remove the bottom kick panel,you should find a tech sheet either on the kick panel or taped in the cabinet area down there and it will tell you how to manually put your fridge into defrost, you don't want to work on it while it's running or you'll make it worse,you'll know it's in defrost when the compressor shuts down and the fan in the freezer stops blowing if you can't find it shut down the fridge or unplug it again,remove the food from the freezer,if you're handy remove the back inside wall of the freezer and with a hair dryer melt out any ice up in the vents and blow the air from the hair dryer up above the fan motor and in the corners, ,you'll see water dripping where the ice is,heat it up until no more water drips down,hit one side for a few minutes and then the other side for like 5 minutes at a time so you don't damage anything from heating it up to much,or if you have another fridge leave it unplugged for a couple of days.if you can't remove the wall blow the air into the air slots in the back wall panel,in the right and left side corners and then in the middle,have a light or flash light,you should be able to see water dripping down,keep blowing the air in until no more water is dripping,might take you like 30 to 45 minutes to do this,then turn it back on and see if you can feel cold air blowing into the fridge section,if not shut it down and heat it up again,if you see water dripping there's still ice in there,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air up nto the fridge section and the air returns to the freezer through the air ducts,when the door was open warm and cold air meet and forms ice in the air ducts,if the fan is working and depending on your model and next time you write send the model number you could have a damper it could of got damaged but it sounds like all you have is frozen air ducts
Aug 25, 2012 |
GE Refrigerators
