SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
SOURCE: sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
SOURCE: trying to hook my roku box to my sharp aquos 46 in using my hdmi
according to roku support hdmi won't work with the aquos as of today (1/6/2010). i have no idea if it's an hdcp issue or not
SOURCE: HDMI signal cuts out for
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
SOURCE: I am connecting Roku to an open HDMI port but I
In your TV, go to Menu, Settings and then turn on the HDMI port. Hope this helps Fix Ya up.
