20 Most Recent Roku Streaming Stick HDMI Version Questions & Answers
when you click on the hulu app, it should ask you if you are a member or if you want free 30 day trial, click on 30 day free trail, it should give you a code, then you will have to go online to the roku or hulu site to enter the code
Roku Streaming... | Answered on Apr 30, 2018
You have a slow Internet connection. This may be caused be the Streaming Stick being far from the wireless router. The best way to watch Netflix is to have an internet connection of 25/25 Mbps and use a wired (ethernet ) connection to a Roku 3 for example. If you are using DSL that would be a problem because of slow internet speed. Try to imorove the position of the router closer to the Streming Stick if possible. I stream at a distance of 30 ft and it never buffers with a wireless connection to a 720p TV and have a wired connection to a Roku 3 10 a 1080p TV and it works beautifully. Good Luck!
Roku Streaming... | Answered on Apr 15, 2018
Roku Streaming Stick® (HDMI® Version) (Model 3500 ...
https://support.roku.com/.../208754808-Roku-Streaming-Stick...
Roku, Inc.Connect your player Step 1: Insert the Roku Streaming Stick (HDMI Version) (Model 3500) into an available HDMI port of the TV. ...Missing: jailbreak
Roku® Streaming Stick® offers all the channels through HDMI
https://www.roku.com/products/streaming-stick
Roku, Inc.The small size of the Roku® Streaming Stick® means you can easily plug it into just about any TV with HDMI® and start streaming your favorite content. ... (for remote); USB power cable + wall adapter; Get started guide; Special content offers.Missing: jailbreak
Roku Streaming Stick channels - YouTube
Roku Streaming... | Answered on Nov 18, 2017
The Headphones must be plugged into the Roku 4 remote control to work with Netflix.
Roku Streaming... | Answered on Jul 09, 2016
The batteries and either low or dead, or the Remote needs to be Re-paired with the player (Roku 3 and Roku 4). Open the battery cover on the remote and look for a small button and hold it for 2 seconds, this should make it start to resync with the Roku Player.
Sounds like you have a bad connection on either your roku stick or your HDMI PORT.Does you ROKU stick show a white light if not check power cable or electrical plug.
Try wiggling ROKU stick just a hair or push it in and out until you get a signal..A purple screen with the words ROKU should show up on TV.If you have a bad port on TV it would have to be replaced but this is rare,if you have a second port on tv try that.Have you tried your ROKU stick on another tv?Does your streaming stick go in vertically or horizontally,if it goes in vertically it may be pressing against side of tv prohibiting a good connection.You could try a HDMI cable, plug the HDMI cable into tv and put ROKU in other side of cable.There is also a restart button on ROKU stick push it and it will start blinking,if it doesn't light up you may have a defective ROKU stick.
Roku Streaming... | Answered on Feb 26, 2016
Go to Roku.com/link and enter the code where the screen says Link Code
Roku Streaming... | Answered on Jan 02, 2016
If you plug the Roku into the back of the TV in an HDMI port, you need to hit the Input button on the TV to change (probably) from HDMI1 to HDMI2. Once you are on HDMI2, you should see the Roku emblem. Then you need to set up the Roku to see your wireless signal.
Roku Streaming... | Answered on Dec 16, 2015
I'm just guessing here, but it sounds like a power issue. Try an alternate power source, maybe a bad cable, or defective power adapter.
Roku Streaming... | Answered on Apr 20, 2015
If it's only been used once, I'd suggest you return it for replacement.
Roku Streaming... | Answered on Mar 21, 2015
remove the little plastic strip that is keeping the batteries from touching the contacts in the remote.
Roku Streaming... | Answered on Mar 08, 2015
https://my.roku.com/signin to do it, or the website specific to the channel you are attempting to access.
E011 usually means that the firewall in the router is enabled. Disable the firewall , setup Roku, and then enable the firewall.
Roku Streaming... | Answered on Feb 03, 2015
Roku Streaming Stick HDMI Version Logo
71 questions posted
Top Roku Televison & Video Experts
ray gallant
robert
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Roku Televison & Video
Most Popular Question
light just blink green doesnt let me
  • Televison & Video
