20 Most Recent Polaroid PDM-0082 Portable DVD Player Questions & Answers
It sounds as though someone used a harsh chemical on the case that is not compatible with the finish. This will soften the plastic and cause the issue you state. Once this has occurred, there is no getting the genie back into the bottle.
Polaroid... • Answered on Nov 29, 2014
Push the ( IN OUT Button) and check the ( Source Button )
Polaroid... • Answered on Mar 29, 2009
Your three yr old has not shut you down. Open the lid of the player and make sure that the lens still slides backward and forward. If this is so, get yourself a clean cotton swab dipped in either methylated spirits or rubbing alcohol, and thoroughly wipe lens in circular motions. Few seconds to dry and you should be ok.
kev tech.
Polaroid... • Answered on Jan 08, 2009
If you switched DVDs and you plugged it into an electrical outlet and it is still happening, you should take it in to have someone look at it.
Polaroid... • Answered on Jun 17, 2008
If you find that the DVD is not spinning it might means that the the "spinner" is not functioning, the sound you hear is the laser moving up and down trying to read your DVD but since is not spinning it can not read it. You will need to replace the small motor that operates the spinner, after extensive use they just give up. I hope this is helpful enough.
Polaroid... • Answered on Aug 30, 2007
The manual doesn't mention anything about removing the back panel or doing DIY repairs. But you can phone them and they will give you advice for free. Questions? Need some help? Call our 1-888-896-9859 helpline: https://www.directutor.com/content/user-manual-polaroid-polaroid-tlx-04243b ..
Polaroid... • Answered on Apr 26, 2021
Use code search on your GE URC to find something that works. You may need separate codes for TV and DVD player. If a search through all codes stored in the URC fails, try a different one.
Polaroid... • Answered on Apr 03, 2021
  1. Ensure that your Samsung Smart TV is connected to the Internet.
  2. On your Samsung Smart remote, press the Smart Hub button to go to the Samsung Home screen.
  3. Scroll to and select Apps, and then select the Magnifying Glass icon.
  4. Enter Spectrum TV, and then select Done.
  5. Select the Spectrum TV™ App, and then choose Download.
  6. Once installed, select Open to begin using the Spectrum TV app.
  7. When prompted, enter your My Services Username and Password.
For further assistance, visit Samsung Support. http://homenol.blogspot.com/ http://electrohelponline.blogspot.com/ /
Polaroid... • Answered on Mar 01, 2021
Request the manual from Polaroid.
Polaroid... • Answered on Jan 04, 2021
Could be main board fault, could be screen fault, could be backlight fault. Only you will know after testing each item in question.
Polaroid... • Answered on Dec 21, 2020
Polaroid PDM-0082 Portable DVD Player Logo
10 questions posted
Top Polaroid Televison & Video Experts
Paul Bade
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
exterior surface dvd pdm 0082 become
  • Televison & Video
