I do not believe the Seiki SE40FYM has a QAM (unencrypted digital cable) tuner. The specification sheet for the SE40FY says that the model has over-the-air ATSC and NTSC tuners. See https://www.qvc.com/footers/el/pdf/E227730_SpecSheet.pdf . The M indicates that this model was sold through one store/chain.
WalmartShop all · No-Contract Phones · Unlocked Phones · Prepaid Minutes & Data ..... Seiki 32" Class LCD 720p 60Hz HDTV, LC-32G82 ... 1-20 of 45 total reviews ... for an inexpensive 32" TV for our guest bedroom and came across this one and ... Walmart is sending me a replacement and if it works well, I will update my review.
WalmartSeiki 32" Class LED 720p 60Hz HDTV, (2" ultra-slim) SE321FB .... I bought this as a gift for my girl friends home bar...we were booth very happy with the tv.
? 1:42
https://www.youtube.com/watch?v=OZlNRxBe1fg
Feb 28, 2014 - Uploaded by Kevin Davidson
+Kevin Davidson Uhm how do I manually set my dns settings? ....Can u help me can u go on amazon and type in seiki 32 inch tv if its the same one as yours ... Can you help me purchase SEIKI LED SMART TV and would like to change .... Seiki SE50UY04 50-Inch 4K UHD 120Hz LED HDTV Initial Setup ...
QAM codes are to do with the way digital TV is encoded. There's nothing practical you can do with a QAM code. It's like understanding how to calculate the mass of Jupiter. Great that you can do it. But it's of no practical day-to-day benefit.
Here's some reading on Quadratic Amplitude Modulation, for what it's worth.
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Check and replace its main system control memory IC, and re-program it with initial data. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there.
Hi. No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables. Once in a great while you might even find one that has s-video output, but those usually are expensive.
To get HD channel form your cable TV without using the cable provider HD tuner box but using your TV Clear QAM tuner (your TV has Clear QAM tuner, my TV also has QAM tuner so I do not have to use the cabel box, but my COMCAST does not provide may Clear QAM signals like they use to) to get the unscrambled HD, the cable provider must provide those unscrambled Clear QAMsignals for your TV to pick up the signalS.
Learn more about Clear QAM cable signals: http://en.wikipedia.org/wiki/QAM_(television)
Did you use the correct setup during the tuner setup to scan the availabel cable channel per user manual?
