20 Most Recent Seiki 32" LED TV - SE321FB Questions & Answers
Seiki 32" 720p Smart LED HDTV with Muse Streaming. How to fix Seiki Muse black lines.
Question edited for clarity and typos. Question moved from 'Black Computers'. Take it to a television tech. https://www.google.com/search?q=Seiki+32%22+Muse+black+lines ..
8/20/2022 3:41:20 AM • Seiki 32" LED TV... • Answered on Aug 20, 2022
WHERE IS ON BUTTON ON A SEIKI 32 FLAT SCREEN 2018 MODEL. Where is power on button for a 32 Seiki.
Question edited for clarity. Question moved from Office Equipment to a Seiki Category. '32' is a size, '2018' is a year, neither are 'make and model'. On this model, it is button 5 https://www.manualslib.com/manual/516135/Seiki-Sc32ht04.html?page=6#manual Google Seiki (proper alpha-numerical model number) manual ..
7/5/2022 2:27:16 AM • Seiki 32" LED TV... • Answered on Jul 05, 2022
2answers
How to unlock a Seiki tv forgot pass cod
You may have tried these but I post just in case. 0000 & 8899. Read it in a seiki tv manual. 8899 didn't work for me but maybe it can on your set.
1/24/2020 9:45:53 AM • Seiki 32" LED TV... • Answered on Jan 24, 2020
Power light comes on but screen is dark.no sound no nothing
tv is broken
9/4/2016 3:06:43 PM • Seiki 32" LED TV... • Answered on Sep 04, 2016
How to set up my Seiki TV to receive cable straight from the wall to the Television
Refer its user manual for details. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
8/24/2016 2:20:23 PM • Seiki 32" LED TV... • Answered on Aug 24, 2016
Picture but no sound
check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
8/17/2016 2:54:42 AM • Seiki 32" LED TV... • Answered on Aug 17, 2016
When yuo turn tv on it just keeps flashing seiki on screen
Sounds like corrupted firmware. A firmware update migh make it right. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
8/15/2016 5:45:25 PM • Seiki 32" LED TV... • Answered on Aug 15, 2016
Remote code for seiki se32hytca led tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
8/12/2016 3:34:24 PM • Seiki 32" LED TV... • Answered on Aug 12, 2016
I have to scan my seiki tv every time I turn it on are turn the channels why
I have no sound I tried everything the mute button turn off cc I don't see anything for speakers
8/11/2016 6:45:08 AM • Seiki 32" LED TV... • Answered on Aug 11, 2016
I have lost a few programmes and they won't auto tune back in the TVs. Help please
U can try unplugging and resetting the set. If that does not do it, then the tuner section of set is fubar.
7/29/2016 10:25:30 PM • Seiki 32" LED TV... • Answered on Jul 29, 2016
Seiki 32 inch made a noise and turned off,no light,nothing. What bord should I order?
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
7/16/2016 5:20:21 PM • Seiki 32" LED TV... • Answered on Jul 16, 2016
The remote works but the button operations have swapped, can they be changed?
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
6/17/2016 7:01:53 PM • Seiki 32" LED TV... • Answered on Jun 17, 2016
Volume is stuck on highest setting.
Contact the support.
3/2/2016 3:34:21 AM • Seiki 32" LED TV... • Answered on Mar 02, 2016
Need code to set up remote to cable
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
1/26/2016 3:12:15 AM • Seiki 32" LED TV... • Answered on Jan 26, 2016
Why tv don't turn on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
10/22/2015 6:16:52 AM • Seiki 32" LED TV... • Answered on Oct 22, 2015
My tv suddenly has no sound
First thing I would think of is check the mute button on the remote, other then that you may have to take to a repair shop.
10/16/2015 2:12:16 AM • Seiki 32" LED TV... • Answered on Oct 16, 2015
My tv screen is black and I have no sound,what do I do
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
10/2/2015 5:21:54 AM • Seiki 32" LED TV... • Answered on Oct 02, 2015
32 seiki tv vertical lines on screen and skip some ajustments like tint
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
8/23/2015 4:19:27 PM • Seiki 32" LED TV... • Answered on Aug 23, 2015
Seiki 32" LED TV - SE321FB Logo
82 questions posted
Top Seiki Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
Kardoc
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Seiki Televison & Video
Most Popular Question
button seiki 32 flat screen 2018
  • Televison & Video
