See above
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
